came across this thread im having the same problem. anyone got any solutions?
Digging this up
Tales from the grave :)
I thought this may be better than opening a new thread. I have an intermittent problem with LOCKING my doors (the trunk works fine). every once in a while (happening more often) it is not possible to lock the doors via the remote or the button on the driver / passender door. Locking them with the key or the little handle thing works fine. If I press the remote or the button, the lights flash (as normal) and I hear the some faint "grinding / moaning" from inside the door near the lock - and the door is still open. If I press the remote / button and it locks the doors I hear a load and solid "chunk" as the door(s) lock. Now the question is something else bad (like mentioned relay, fuse, ground) or do I new 4 new door lock actuators? and if yes how to I determine if I need the ones "does not include connector for Anti-Theft system" or the ones with, without taking my doors apart? |
had the chance lately to have my fingers on the relays while pushing the lock button and the doors wouldn't lock, but the relays did a strong click.
So the fuse is obviously ok, since without a fuse it wouldn't do anything. the relay click even if the doors don't lock. Should I next check voltage for the actuators at the relays or is there another prone part to fail. I don't wanna take my doors apart right now. |
I’ve had this problem for along time now but it never bugged me enough to try to fix it; Ill start trouble shooting soon to see if I can solve the mystery once and for all.
as the export models don't honk the horns, it can be quite a security issue if you can't lock the doors and don't recognize it.
I'll be very glad and happy if you could look into this asap |
okay
