Hey guys
i just got the Jensen VM9510 (in dash 7" monitor) and its awsome, but neways bestbuy has a policy where they have to hook it up a certain way where you can only watch movies when your in park with emergency break on. is there a way i can take that feature off. im new to all of this. but any help is good help thanks |
I have no clue, but that is bum.
When i have it running i go to the dvd screen and it says PARKING but if i just pull the emergency break a little bit the screen shows.
if you guys know where the emergencybreak wire is maby i can drop that wire and itmay work.. |
if that was their policy...I would have gotten someone ELSE to install it :thumb:
all it is is a ground wire, that when the parking brake is engaged, its grounded and the screen works.
take the deck out of the dash, look for the parking brake ground, usually black or green, should also be tagged. check your owners manual of the deck if you cant find it, that will say for sure. take that wire, and disconnect it, and reconnect it to the decks ground. so its always grounded, not just when the parking brake is engaged |
Thanks man just what i was looking for im going to check it out
they make a little black box that you wire into the screen. I have the alpine and I had to use it in order to watch movies while I drive. Its like $20 and it taps into like 4 wires. Call a custom audio shop and they can hook you up.
i just thought of something crazy and it worked.
I kept pulling on the E-break until the screen came on. when it did i drove around and the e-breaks werent even on. onlything is when i drive a loud beeping noise will go off for a couple of secs. how do i get rid of that beeping noise. (Same noise it makes when you leave your headlights on) |
by not driving with your E-brake on!
well im am
but the breaks not on. is this agood idea??? |
IMO, don't mess with the E-brake or the beeping.
Just change the ground like it was already suggested. |
alright it was juat a crazy Idea.
anyways im gonna call around for that black box thing. so i can get that fixed. Thanks for your help. P.S. Now if i can only figure out what i need to get my ps2 in there |
use the aux input RCA's...thats how mine goes in...you mgiht have an aux input or a nav input...it will work in either.
out of curiosity how much did you pay for it?
who?
the dude that started the thread.
Check out www.pac-audio.com
They make a lot of bypasses and stuff. Check their dealer or distributor page to see where you can get it from around you. |
It was on sale $599 free instalation
