3500 swap
ive been reading up on it on GAGT and im going to do it,
its a pretty much straight foward swap, and i will get all the benifets of better heads and intake design, probably going to stick with the 3400 upper for ease of swap and just have it ported, that and the 3500 is smoother then the 3400 and newer |
how are you going to get past the DBW?
good luck with swap, make a build thread! |
go 3500 top with TCE tb and adapter
http://www.aleromod.com/forums/showt...ght=3500+grand
some encouragement |
Its going to be running a 3400 top end and its getting a 65 mm tb from wat i understand every thing else is bolt on
your making more work for yourself by doing the 3400 top end, just get the TCE tb and adpater because the 3500 tb is electronic and your good to go, i dont get why tour swapping the 3400 top end on ported when the 3500 already flows well and most likely will still flow better then a 3400 ported
i like the looks of the 3400 topend, though ive been concerding the 3500 topend
quick question is it possable to use the stock 3500 exhaust, it looks cleaner and looks to flow better..
