Coil Overs
Will they fit?
http://cgi.ebay.com/ebaymotors/95-01...spagenameZWDVW |
u have to cut the perch use search button and search for my thread
I've done a bunch of research on coil overs and though its nice they are adjustable in height.....not worth the bone crushing feeling your going to go through while driving the sucker!!
Without getting all into the details, the primary use of coilovers is to improve handling by stiffening the suspension. Ride height adjustment is part of the equation, but not the main reason they're made. If you're going to use coilovers, the ride won't be nice and smooth like stock.
If you want to lower the car, get some lowering springs actually made for an Alero, not a set of universal "coilovers". |
true true but with coilovers its cheaper then lowering springs
I had coilovers once. It sucked for ride. Ride height was great. I felt like I was in a mini truck riding on frame only. I went to cutting my stock springs all at the same amount and it had a better ride than my lowering springs too.
I have a set of stock springs if you want to cut em up. pm me an offer include you zip code
ya true that
coil overs
here are some real coilovers for the aleros and grand ams http://mantapart.com/
sweet man thanks!
not a prob glad to help out..... they are the only real coil overs that i have found. they aren't cheep but then again they are custom and they are Bilstein's
..and they're from Mantapart. Good luck getting anything from them. They have a history of taking over a year to send you your parts, if you get them at all, even after you've already paid for them.
Well, the three magic letters for Mantapart are "C.O.D.". I never had any issues from them that way.
The first coilovers posted will work, I had a set similar to those for a cavalier they fit perfect. I didn't need to cut the perch but I did need to cut a couple of the threaded sleeves shorter because other wise my car would bottom out on the 4" sleeves, other than that mine rode quite nice suprisingly.
could just get the DZ springs there like 50-80bucks shipped
Would I get ricer bounce and a shitty ride? |
ive had them for god 2 yrs or more not bouncy not the greatest ride but still pretty good ask yalero he just bought them
