California Emissions
Ok, here is what I understand about the "Air Pump" on california emissions equipped vehicles. This pump takes a little bit of your exhaust from the manifolds and runs it through a filter, supposedly reducing emissions. A friend of mine had his 2003 Malibu encounter a weird problem. Something with the air system went bad, and his engine bay caught fire, caused by a faulty air pump. The exhaust pressure and heat was being forced into the emissions sytem, instead of being regulated by the pump, and it melted and caught fire (that's what the garage said). What a mess that was. Ended up selling the car to a guy who wanted a project car. Anyone hear of this happening before? I didn't have time to look into it too deeply, but it looked like what I've just described. That being said, is there any way to have this system removed? Maybe reprogram the ECU and plug up the holes? I'd like to hear some theories.
sounds like a heaping pile of monkey fungus to me.. but I dont know much about emissions.. only that it depleats the ozone layer and will eventually cause all life on earth to become festering blobs of cooked meat.
All the AIR pump does it inject a little bit of exhaust into the heads to help with start-up, that's it. The rest of the time, it does nothing ;)
(This is my 12,000th post :yahoo: :dance1: ) |
WHOOO! |
Back on topic. You A.I.R. (Air injection Reactor, yes it true that what its called) did not catch fire. the valve melted, and the pump is melted too. If both these items melted, you need to replace the catalytic converter. Ask him if its "J" motor or not. If "J" I almost bet a new valve and pump will melt within 2 weeks.
hmm.. Quote:
It's actually fresh air that is injected... |
I always thought it was exhaust :blush:
O well :ninja: |
Cool
Good info. I actually had it backwards! Sounds like it makes sense I guess.
