i have a 2001 alero gl i bought it about 2 weeks ago and have been having problems with the front brakes the place where i got the car replaced the front brakes and rotors they put on after market brakes and rotors.
the were rubbing and the front left wheel has been making noise so still trying to figure out what the problem is espically when the car dont even have 18.000 miles on it yet so if anyone else has had this problem could you let me know |
take it back to where you bought it...they should fix it for you if you just bought it
If you have the eagle RS-A's, then they might be making the noise. Sounds weird, but there was something about the bead that made them make a rubbing sound similar to brakes. Most dealers were replacing them for free.
yeah... look at the tires to make sure they're not rotting. Some of the tires on the GL and GX were rotting too fast and that can make bad noise.
if you have eagle LSs you will get a "grinding sound"
my money's on that... for about 6 months i tried EVERYTHING to get rid of it. strangest thing... only happens at LOW speeds (<5mph or so), sounds exactly like something on the brakes is scraping or rubbing. there is a TSB on the rubbing... the dealership (if under warranty) is supposed to replace your front tires only. rotate them, complain again, and they should do the other 2 tires. just make sure they replace them w/tires w/o the "railroad" marks along the bead. if you're out of warranty, like i was, you might get goodyear to give you 2 new tires. i did. then they got pissed when i went home and rotated them and came back. they gave me the second 2 1/2 off. not bad- 4 225/50/16 eagle ls for $116. |
Might be a bad wheel bearing. I replaced my left front wheel bearing about 4 months ago and now it is making the same noises again. Thankfuly there is a 1 yr replacement warranty.
no it wasnt the wheel bearings got them checked right after i started to hear the rubbing noise .but when i got the alignment done this weekend it got a lot quieter so i do think it is the tires but going to rotate them this friaday after i pick up the new tires so see what happens then.
jim |
got 2 spare wheel/tires? maybe 2 spares? that'll weed out whether its tires or not... kinda a PITA, but whadda ya gonna do?
