interior neons
I want to install interior neons, but I see that the aleros havea one pice dash going on does that mean I am going to have to take off the entire dash to install these?
NO! Where do you want to install them? It's very easy to take apart our cars. It all depends where you want to install the neons. And I think leds would be better.
I want to put one under the driver side an one under the passenger side and then I have leds for the middle little cubby thing
alright listen man, you dont need to take anything apart, put them right under the dash! why would you take the whole thing apart????? this is a simple install
to instal the switches and wire them up I need to get like behind the dash so I figured I would have to remove it becuase its not in pieces like my accord unless I put the switches someplace else
yea pretty much lol
You dont have to take the dash apart to wire it up, put one neon tube on each side, run a wire to each one, then run that wire to the fuse box on the driver side, and then you just hook it to a fuse that is on when the car is on.
the wires you can just tuck under there somewhere, i havent been under there for a while so i dont remember, but my leds were simple to put in. |
oh and make sure you put the tubes where nobody will kick them:lol:
Oznium.com for all your LED and question needs :D
yea, they are a great place to shop from, great customer service. If you end up buying from oznium and you buy the "prewired LEDs", make sure you get around 6 (3 leds for each side), cause 2 isnt too bright, i just put pink leds in my sisters car and i used 2 prewired for each side and they definitly give out a good amount of light, but if you are looking for a lot of light i would say go with 3 for each side. |
ha! i have 7 on each side....
one on the drivers vent, 2 in each of the centers, and 2 on the passagner vent. not to mention 3 in each door cubby. 5 in the center console, 2 in the center console cubby, 5 got gauge lights... ...of each color i posted... and 12 white, as a dome light. Prewired is for newbs. lol |
14 on each side, 7 green 7 blue. 1 of each color in the door slits and center cubby and 3 of each under the seats glowing to the back, and 18 of each color in each wheel well. lol lotsa leds and im still not done :)
Showoff, eh?
2 red LEDs in each large vent, 1 red LED in each small top-dash vent. 2 red LEDs in radio pocket 2 Red LEDs in cup holder 1 4" red neon in each door pocket 1 7 color LED in each speaker grill (front door) 1 7 color LED in each door handle (all around) 1 7 color LED in the rear handle-ish places where the screw cover is on the back doors 2 4" blue cathodes in the middle under the dash 2 10" red LED bars shining down onto mats under dash 2 10" red LED bars shining forward from under seats 2 4" cathodes in the rear seat lip 2 10" red neons under the back of the front seats 2 4" blue and 2 12" red cathodes on the roof 3 red LEDs in the roof map pocket 2 red LEDs in each seatbelt hole red bulbs all around for map/dome lights 1 4" red neon per rear speaker grill And one strobe that flashes under the dash when the subs are on That's my setup... And that's only the interior :) |
lol sorry but chris's 2 color cluster out does us all............well, except for marc, could have seen his car from outter effing space!!
When you are putting in neons on the interior where do you put the wires in the fuse box on the drivers side? I found a place to put them so they turn on but they don't turn off when the car is off...they just stay on. I ended up blowing a couple fuses trying to put them in lol it would be very helpful to see a picture of how its done.
Uh, the radio fuse... or use a switch and tap into the cigarette lighter wires...
easy peazy, passenger side box, sunroof fuse, even if you dont have a sunroof, theres a fuse for it, use it, it works! |
radio fuse and cigarete thingys are all constant, atleast in my car
^^ fyi theres an edit button so u dont need to double post.
anyone live around akron want to help me put the pieces under my dash back together? i cant figure it out!! arrg frustrating |
