Throwing Codes
DTC P0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
Any ideas on what causes this? I know it means that I've got low vacuum, but I am at a loss for what is causing that. I can't find any vacuum leaks. Unless there is a :ninja: leak somewhere. The car idles hard which I know I need to replace the IAC, but I'm waiting to do all the engine work at one time, when my supercharger gets here. Is it just the MAP sensor? If it is I'll just pick one up and replace it when I replace the IAC and install the supercharger. If not, any ideas are appreciated. |
hahahah well, the supercharger could take another week, im not doing so good in life and
well, problems between family members :/ |
I think you've got me confused with someone else. I bought Ion's old super.
Yeah, but I need the manifold that Nate is fabricating first for the other supercharger. :/
That code can be a faulty MAP sensor, or crappy hoses going to the MAP sensor making for a vacuum leak and a faulty signal to the MAP. Supposedly the hose likes to crack. |
This should help.
I had no idea about that. He probably thinks I'm either a rooster or a tard now.:lol: Quote:
I'll check the hoses again, maybe I missed something, or I'll just replace them. Cliff - thanks for all the intel, if the hose replacement fails me, I'll start moving through that list. |
