Saab 9-3 ecotec swap
I was wondering if anybody here ever looked into swapping the saab 9-3 turbo ecotec in, im thinkin i might wanna try this what would i need? And would i need new tranny
why not just a normal ecotec and turbo it, seems kind of retarded to me..
Sounds very interesting...
Not sure if the trans is different or not, I would assume you would need to replace the trans. Obvious things are PCM & BCM (which will cause difficulties, since BCM is different on the SAAB; you would have to get the SAAB PCM VIN changed) + coolers, harness, etc. May not be worth the work. Just going from a 2.4L to an ecotec was a lot of hassle. |
Well i can get a turbo for wat like 4000 or the saab engine for 800 and do they still make the eco s/c kits all the stores say discontinued, i havent gone to the dealership though
I say that it will mechanically doable but the wiring will be a PITA because it's a SAAB engine and the sensors and ecu are not the same..... and IIRC the SAAB use the F40 6 speed tranny...
yea doesnt sound worth it, but the turbo and turbo manifold will still fit right? IIRC all the ecotec manifolds are interchangeable so i can use those
I've been thinking the same thing and i believe the manifolds are interchangable. u would probably need more than the manifold and turbo though. Check out jbody.org, they seem to have alot of turboed ecos on there and u can research it more. or other eco sites that i can't remember the name of. I would make sure to do ur homework before jumping into it thou.
Thats not a bad idea to take the manifold and turbo. Actually, I don't know jack about turbo SAAB, but I'd guess you'd need the downpipe, the intercooler, and some custom piping. Then you'd need a new MAP sensor that can read boost, then custom tune your PCM. But it could be feasable that way.
yea im derfinitely doin my homework, and i know theres more to a turbo than the turbo and manifold. im thinkin im gunna do it unless i can find a s/c kit for the eco lol
This is what i was thinking of doing, getting saab turbo, manifold, injectors, custom fab piping, intercooler, down pipe, HP tuners, gauges just for starters.
yep yep yep, my thoughts were if the s/c on the lsj would fit then the turbo from the lk9 should fit. i just gotta get all the parts and HP Tuners, and with sum serious research ill do this by fall
I am looking into purchasing a 9-3 right now and from what I have found in my research the head on the Saab 2.0 is different from the other eco's which means there is a possibility of different spaced or shaped exhaust ports.
It has all the upgrades the LSJ has but with a turbo. 1) Piston Oil Squirters 2) Oil Cooler 3) Forged Crankshaft etc... Just make sure you get the LK9 / B207R and not the LQ8 / B207L |
so you could make your alero 6 speeds,nice,but is it easy to do?!? |
if you want it that bad maybe try swapping entire chasis?, like a body swap, not shure how similar the 9-3 is
y th hell would i do that? im talking about using the turbo components not the the chasis
It's not a Saab engine really.. It's just a LSJ with a turbo instead of a supercharger. Just swap it over using the existing harness. The Saab either uses a F35 or F40, depending on the year. |
i like the idea...u gotten any prices on anything yet?
(except the 800 for a full engine) |
ok sry you but that v8 alero was on an s10 chasis wernt it
and i was wondering if a cobalt transmission would work with teh aleros ecotec |
