How to remove rear bumper
Searched, and found nothing,
how do i do it? seems pretty well on there |
you have 3 screws and a clip in each wheel well and then you have the clips in the trunk opening and there will be i believe 2 more clips on the bottom.
ok, cool, it's on a lift, so it should be easy then |
yea the 2 clips on the bottom I had to ut off when i got the razzi, and arent used on the AAS
But thats it, pretty easy, just take your time |
there are no bolts correct? |
just like oldsman said 3 screws on wheel well, and 1 plastic clip, I beleive you need a flathead to pry up the pop thingy on it and then pliers to pull n remove, same with the 4 on the top (under trunk)
(screwdriver- flat head and phillips and pliers) should get it off for you. |
and theres at least 2 fasteners under each tail light
you mean screws? I forgot about them
don't remember if they were screws, bolts, or plastic pushpins, so fasteners covered all of them ha
lol, if my memory is right they are just small big headed screws, but fasteners is what I wanted to call them push-pop thinky's
they are gm pushpin fasteners, and some are a PITA. |
If it's anything like my Escort, it's about as easy as doing an oil change.
lol easier....id rather remove my bumper then do an oil change, lmao but then again I never did my oil myself.
Both bumpers and side skirts were a pain in the ass for me, but I did mine outside, on the ground, while it was snowing/raining.
yep 2 screws per side......forgot about those. |
Did it, all done
here's the spec bottom, four push pins top, four push pins Under light's, two, (four in total, screws) wheel well, three screws was cake, thanks guys! |
What did you replace it with? Was it as easy to get the new one on?
Doing it by yourself, installing a bumper is harder than removing it since you have to line stuff up. Still not difficult though. |
i never replaced it, i had to weld my striker... it was completely rotted off the car lol
wanna come down to ma and do mine?
get me a portable welder...and sure |
