Throttle Body Performance
Looking for an upgraded throttle body as well as a throttle body spacer to go with it. If theres no bigger or better throttle body's out there, then Ill just get the spacer.
Anyone selling one or have any good sites to suggest? |
What kinda gains would i get with the the billet TB? |
a TB is basically a supporting mod, you won't see much from it but it will help increase gains from following mods. so maybe 1-2hp for now |
ok thats what i was thinking lol xD |
Im looking to get a bigger throttle body as well as a spacer, fitting it with a cold air k&n and after some savings a nice borla exhaust off a grand am. they say it will fit. after that ported and polished upper and lower intakes and cams. then a nice chip :ninja: :posi:
There are no chips for Aleros.. You want your car tuned? Buy or find someone with HP Tuners. |
gtfo. |
More like 10 crank HP with a matched TB opening on the upper intake.
I've got ported heads and a cam for sale for cheap. $400 for the whole setup. Pm me for details.
yeah there is no chips for our cars, you buy one your gonna mess up your car. your best bet is to tune the car, not chip it.
there are those 'universal performance chips' that promise more horse power and better gas millage. they tap into the intake air sensor wires. I know from experience, they are shit. I took it apart, its literally just a big resistor. other then that, sounds like a good plan.
I have the 65mm TB and I love it. Of course my UIM is ported for a 65mm TB.
Your only going to move as much air as your smallest opening will allow |
Should be noted here that the situation changes quite a bit when boosted, and there are other factors than just the diameter of the opening, even for N/A setups. |
and i found a venom chip. its about 300-400 USD i wanted to try it but now I dont know
THE CHIPS DON'T WORK...THERE SHOULD BE NO CONSIDERATION |
Dude don't buy that shit.. If you want a precision tune tailored to your specific mods then you want HP Tuners.. Its $500 and you can tune your car to your specific needs. If you buy that Venom crap you're only wasting money because it's not going to be geared towards your specifc application.. Like I said there are no chips designed for Aleros that will EVER be able to outperform a solid tune that you can only get from reflashing your PCM(ECU)... HP Tuners is the only software that is readily available for purchase that can reflash our PCMs.. You want to make power the smart way, not the stupid way. |
www.milzymotorsports.com
Go there, 3400 section. He's got PCM's available tuned to support whatever mods you have done. A hell of a lot cheaper than buying HP or getting it tuned professionally. If you have not used a tuning program yourself before contacting Milzy may be your best bet. To hell with that chip stuff as the guys are saying, either get a PCM that is already set up for your mods, or get the HP program yourself. If you do go the HP Tuners route, you'll get lot's of help from us here to get you going. Be warned though, although I do consider myself the village idiot, I'm really not that kicked in the head and it took me a couple of years and literally hundreds of hours to get comfortable with the program! But, with the number of us that do use it there is tons of support floating around to get a good base tune nailed down and then the ball is in your court to clean it up to your liking! |
Throttle body spacers have been proven to do nothing!
what about i saw something on ebay, you unplug your MAF sensor, plug this device in the end of the wire, and then plug the other end into your MAF.
its supposed to help with cutting fuel when you dont need it. http://www.ebay.com/itm/Advanced-Power-Tuner-Chip-High-Performance-Save-Gas-Unlimited-/111528266463?pt=Motors_Car_Truck_Parts_Accessories &fits=Year%3A2003|Make%3AOldsmobile|Model%3AAlero| Submodel%3AGL|Engine+-+Liter_Display%3A2.2L&hash=item19f79a4adf&vxp=mtr |
