does this sound like head gasket
No smoke at all but my spark plugs keep getting rusted over. The whole tip and electrode
I doubt what you're witnessing is actually rust... If you take a picture, you'll probably get more accurate answers. How new are the spark plugs? Have you notice any misfires, lower MPG or performance?
Brown or dark orange color( I cleaned them so maybe a pic n a week or 2) in the last two weeks its been feeling slower. I when I taped the gas it was leaning out and when driving it wasnt stayn in picking up. Wide band was going between 14- 16 wile driving usually oracle12-15 before boost.
what are you tuning with? What heat range are you using compared to stock and how much boost?
I'm not tuning it. I go to a Tuner shop hptuners. Running about 12 boost stock compression.
does it stumble when it starts up? (burning off puddled coolant in cylinder(s))
pull spark plugs after sitting overnight and look down inside and see if there's coolant in there |
When I first got it back from tuning it started quick now it takes two to three cycles to fire.
i don't care about that, i said stumbling
vibration, enging running rough, shakiness only for the first 3-10 seconds after it's started |
Naw it doesn't do that
What spark plugs are you running?
A Stage colder copper spark plugs Ngk
may want to try 1 more step colder. What kind of gap?
ss
.026
Ion I pulled the plugs this morning no liquid but there was what look like burning in cylinder number 1 the rest where shiny .
all of the cylinders where coolant entered, the piston was nice and shiny for me..
Head gasket time yeahhhhhhh. Fml.
Thanks for the advise everyone. |
that doesn't mean it's the head gasket
how does it run? if the head gasket was failing, at high throttle coolant would blow out and the car would be getting hot too, above half and never coming down. |
It runs good. Even tho its auto and I drive like stick most of the time. I blow off between gears. Only thing I notice is, when it starts cold to stays from 10.3-11 one the wideband gauge. After it warms up for about ten mins it goes lean and cuts off if I don't tat on the gas. If I keep it from cutting off for atleast 5 sec it runs perfect. If cut off when I restart its good.
Heats stays under half most of the time. Only reaches half or a hair over if I'm really pushing it. |
