strut/spring questions
looking into a new suspension setup with canuck springs and kyb agx. however i have only found struts for the rear...are there ones for the front? unless the front doesn't even need that type of strut...
also i've heard about moog, i'll probably end up getting those mounts too is there anything else that is needed? (other than installation tools) |
Hard to find agx for front... Good luck.
You need spring insulators too |
yea, the GR2 is probably a better option then... if my insulators are in good condition then i'll just reuse them, or find OEM replacements. thank you |
No problem.
even if you just get the agx for the rear you wouldnt be able to go up or down necessarily but you could adjust rake and give it a nice stance. everyone who gets them loves them, but that being said im going with the gr2's myself.
