hi there.
i got another problem due the lack of gm parts here in germany. :) speaking of the rear bulb terminals in the trunk (the ones u can remove from the trunk due turning) when you pry out the bulb from the terminal you can see that the bulb socket is connected to the cables via "stick in" cable shoes. here is the problem: i need those lil cable shoes. may be about 10pcs or so. it sure is a "1 cent article", but its giving me a hard time to get them. would someone be kind enough to help me w/ this issue? thanks in advance ^-^ ron |
*bump!* ;)
i have no idea what you are talkin about, you have any pics??
sure ill get one today. :)
