01-01-2009, 10:33 PM
Turbo Kit
I Was Looking On Ebay And I Seen A Turbo Kit Called Gmotogarage Turbo For $640.00 Is It For Real It Sounds To Good To Be True!!!
01-01-2009, 11:19 PM
post the link
01-01-2009, 11:23 PM
01-01-2009, 11:27 PM
Looks like a generic kit, that you could possably fab. for cheaper.
1999, RED Alero GX
01-02-2009, 12:04 AM
its just a starter kit. Not a turbo kit for the Alero. The charge pipes most likely will need some adjusting. You still will need a turbo manifold, wideband and gauges, hp tuners or a shop to tune it, down pipe, bigger injectors.....etc. Its not as easy as it looks. That kit is just to get you started.
I had that turbo and trust me you dont want it. It began to rust....just go with a garret or Greddy for real performance. Save up and do it right.
01-02-2009, 03:30 AM
Boost Guru
That's no kit. It's a bunch of parts thrown together and called a "kit", and they're all knock off parts on top of that. Nothing in there is a bolt on part. To use the intercooler pipes, they'd all have to be cut and welded to fit an Alero and there's not even an exhaust manifold.
There is no kit available for an Alero. You would have to piece all the parts together and build your own kit, and if you do that, stick to quality, name brand parts. There's no way to know how long those knock off parts will last, and if they go, they could take your engine with them.
01-02-2009, 04:54 AM
there isnt even a web site for the company JDM Circuit, at least not one i could find.
1999, RED Alero GX
05-28-2010, 07:55 PM
old thread, but Milzy does make an N-body turbo kit, but at 4500 bucks, it would probably be much more reasonable to piece it together yourself with some custom made turbo manifolds.
1987 Honda Rebel 450
