08-03-2009, 12:32 PM
The Aleromod PITA
holy **** how do i fix this!
Originally Posted by KC9LDB
ALRIGHTY! I believe that I have stated this post on the forum before. There is a TSB (technical service bulletin) out for this, released like in 04 for lack of and or poor antenna reception. It is the antenna coupler located right behind the passenger side door still plastic thingy, you can take it out by pulling it out, there is only like 2 clips on the 4 door models..
It literally says, "To fix, reconnect antenna line male end to antenna line female end, wrap in duct tape.
Location of the door plastic thingy that you need to pull off
Notice the duct tape, yeah do this to fix it.
i was trying to do this fix when i pulled slightly and this happened
08-03-2009, 12:40 PM
is that even you in the pictures? if not (or even if so) what is the point to this thread?
08-03-2009, 12:43 PM
Goto a local stereo place and have them put a new connector on for like 10 bucks or something. Would cost you more to do it yourself because you'd have to buy the tool to do it.
08-03-2009, 01:01 PM
The Aleromod PITA
the bottom two are me and it come apart, i was trying to do the thing from the quote
08-03-2009, 01:13 PM
The Aleromod PITA
omfg its this a fix for if its been coming apart,
now i think i misinterpreted and effed up my radio.............
eff eff eff eff eff
08-03-2009, 01:16 PM
1) learn to type coherent thoughts. I can't understand what the hell your talking about.
2) just go to a local radioshack and get the female Motorola Plug( http://www.radioshack.com/product/in...ductId=2102836) . Instructions as how to replace it are on the back of the package. Its not the end of the world. VERY EASY TO DO
OR
2b) remove the male end of the other wire, and solder the two together. Why bother have a disconnect in it?
08-03-2009, 01:28 PM
The Aleromod PITA
OR
ive never had any luck at connecting these types of wires together.
as for soldering and reconnecting the way ive tried it in the past was to strip the rubber back, and take the braided wire and twist that, do the same to the other end,
the i try to the the inner wire the same way and keep it separate, then connect the two inners to each other, and connect the outers to each other, then seal
this usually only works half ass after ive done this to anything
08-03-2009, 01:34 PM
if you never have luck why keep trying on YOUR car haha
08-03-2009, 01:55 PM
The Aleromod PITA
that experience on this type of wire was on a 91 Toyota celica
08-03-2009, 02:31 PM
The Aleromod PITA
i got it working
08-03-2009, 02:33 PM
Saw the author. Saw the title.
Expected more.
08-03-2009, 03:13 PM
Sorry, You attempted to fix something that wasn't broken?
You tried to take it apart, put it back together, then duct tape it, Even though it wasn't coming apart?
I hope I'm reading this wrong.
08-03-2009, 03:42 PM
The Aleromod PITA
yes your reading it right i had a huge brain fart
08-03-2009, 03:49 PM
thats not a brain fart... thats a brain...colt .45 magnum to the face.
08-03-2009, 03:57 PM
Expected more.
i wax expecting his head in his hands
08-04-2009, 12:13 PM
Hahahahaha.... That made me laugh.
Under construction...
08-04-2009, 12:54 PM
Si vis pacem, para bellum
my IQ i belive has just dropped 20 points....
