06-04-2008, 10:48 PM
#21
well today we took the valve covers off and all the rocker arms and springs are all fine, after a little thought we cam to hte possible conclussion that it is more than likely that cam shaft or crank shaft either way that requries a complete tear down, so depending on if i feel like messing with it or not depends if im gonna just buy a new motor or try to fix
06-16-2008, 11:10 PM
#22
to find out no rods are knocking and 7 out of the 12 lifters are bad gotta love it
1 and my cam shaft has a couple wear spots
06-17-2008, 12:34 AM
#23
Not too bad then. I would still recommend opening the oil filter and looking for copper. If the cam was in that bad of shape, the cam bearings are likely pretty worn. It will be obvious when you pull the cam when you see the journals.
My cam journals (the two in the center) were in horrid shape, and there was considerable wear in the bearings. Some folks think there is a bit of flex in the stock cam. I would be curious to see some pictures of yours. Here is a quick shot of the carnage on my first tear down:
06-17-2008, 01:25 AM
#24
i dont think mine was quite that bad but i'll try and get a picture of it next time im over there working on my car
i'm replacing the transmission while i got the engine out since i had 130k miles on my car and found out the transmission was probably about to go out, i went ahead and got a new transmission with 65k miles for only $100 not to bad really.
if i keep this engine more than likely i'm going to go ahead and clean out the sludge build up inside the engine, replace the camshaft, get a whole new timing kit ( cam gear crank gear and chain), new oil pump ( just to be sure that wasn't the reason the lifters quit working), replacing the lifters obviously, new rods and new spark plugs
The reasoning is junkyards want to try and charge $750 for a engine with a lot of miles ranging from 120k-180k all at the same price when i will be better off to just replace all the parts in mine and have basically a newer engine,
06-21-2008, 07:37 PM
#25
turns out it wasn't just the lifters that were messed up within my engine, took apart the bottom end of motor today and found out that 1 of my rod bearing where bad which i;m thimnking maybe the oil pump was went wrong first
06-21-2008, 08:46 PM
#26
sounds like your taking this project on, in a quite positive nature. good luck with the rest of the tear down/build up.
06-22-2008, 02:35 AM
#27
Good luck with the rebuild and keep us posted about it.
06-22-2008, 08:16 PM
#28
ya i have no choice about the way i take this project on gotta get it done, just found out gf was prego so at least im gonna have a more reliable engine now!
today i also found out th cam bearings need to be replaced as well
06-22-2008, 08:23 PM
#29
OW...man u ever run with no oil?? or with dirty oil?? jeez never seen this b4 with a good oil system.....
EDIT: NVM you said that the oil pump was bad
07-06-2008, 05:21 PM
#30
so my engine is now rebuilt and car ruins again, i replaced the oil pump, the screen at the bottom of the oil pump, piston rings, cam bearings, oil sending unit, spark plugs, also replaced my transmission that had 130k miles with one that had 65k on it for $100 and maybe a couple other things i forgot
07-06-2008, 05:42 PM
#31
glad to hear you got the issure resolved, thats quite a bit of work. shoulda rebuilt for boost
