02-24-2009, 02:44 PM
#21
a little off topic, but is there any way to "clear" the third brake light, i really want a clear third brake light
02-24-2009, 03:05 PM
#22
V.I.P baby
u could use some plexi or lexan I thought about it but, it would be hard to attach it to the 3rd brake light housing,
I made my own led 3rd brake light though its really not hard i got a piece of lexan and drilled holes for the leds and poped the in the hole wired them up and put it back togather
Not now CHIEF Im in the effING zone!!!
02-24-2009, 05:37 PM
#23
Originally Posted by bratch15
Gota bring up an old thread. I wanted to install an Impala 3rd brake light and according to toddbobby, you only have to sand the edges to make it fit. Are the mounting brackets the same? Is the plug on the Impala housing the same for the Alero?
the mounting brackets and the plug on the impala's are not the same as an alero's. when i installed mine i didn't sand anything on the impala's led circuit board, i just pushed it into my stock 3rd brake light housing.
99 alero - totalled
96 impreza 5spd awd - sold
02-27-2009, 07:44 AM
#24
^^^^^ So did you have to take the impala brake light assembly apart to wire it?
02-27-2009, 07:50 AM
#25
Boost Guru
You have to take apart the Impala housing to get the LED strip out, and you have to take apart the Alero housing and take the bulbs out. There's nothing to trim or sand, but you have to glue the LED strip into the Alero housing. I used a hot glue gun and put a couple dabs of glue on the top and bottom of the strip and it holds it in place pretty solid.
There's nothing to wire, you just take the wires from the LED strip and insert them into the main plug that the bulbs were plugged into and tape it up with some electrical tape. Then you just pop the lens back on the Alero housing and put it back on the car.
The end result looks like this:
02-27-2009, 09:23 AM
#26
^^^^ Alright, thanks. I wanted to do it ever since I saw you had done it. It looks good.
03-08-2010, 04:14 PM
#27
i love the look of the 3rd led, gonna perform this mod now that the weather is warmin up
04 Alero 3.4
03-17-2010, 02:56 PM
#28
Yeah i have done this mod before. Atmosphere has that set. but I did have to sand the edge down so that it would fit in the alero housing. As to having it wired in, I just soldered the wires from the led strip into the place where the stock bulbs got power from. It was really easy.
For the clear lense thing, yeah you would have to be able to make a mold of the red lense and make a clear lexan thing to place in place of the red one.
Once i run into some good amounts of money i would like to go out and buy some PCB stuff, and work on making LED's in a circuit for the third breaklight, and learning how to fiberglass, and make lexan lenses.
