02-27-2009, 07:00 PM
#21
02-27-2009, 07:01 PM
#22
Originally Posted by adam337
i shall strip search ebay for you..
If you find one that be great.
#23
I just want the plastic cover.
02-27-2009, 07:24 PM
#24
think a piece of plexi would work for a replacement?
02-27-2009, 07:35 PM
#25
^Unless you could cut it to the shape, and make it contour, probably not.
02-27-2009, 07:50 PM
#26
This blows a lot.
02-27-2009, 07:59 PM
#27
damn dude u eff'd up on this one wat'd u do try to separate witha screwdriver? ur not gunna find just the plastic, nobody dremels it off and leaves it that way, just get a new cluster from the junkyard
02-27-2009, 08:02 PM
#28
I guess now to eBay.
02-27-2009, 08:15 PM
#29
good luck finding just the clear cover lol.. buy the one i showed and just take the plastic and throw the gauges lol
02-27-2009, 08:24 PM
#30
I found one for 15$ I'll bid for during last mine I also have to pay for my Tsudo Stainless Steel Headers.
02-27-2009, 08:37 PM
#31
may i ask how you broke the plastic piece? lol
02-27-2009, 08:43 PM
#32
.....dremel cracked as I was trying to take it apart
02-27-2009, 09:05 PM
#33
careful you dont have that thing going full speed....cut it slowly so after you finally break it loose it doesnt mark up/break the pieces.
I found that out when i was drilling out spot welds and broke one of my spot weld drill bits....slow and steady until the 5/16 bit drills the hole, then after it pulls through the hole slooooooow down and continue drilling the spot weld with the little teeth on the side.
Point is....when drilling on delicate parts like you were.....you have to be extra careful not to go crazy and try to get it done fast. Take your time
02-27-2009, 09:26 PM
#34
Yeah kinda learned that that lesson from letting my friend do it cause it's his dremel.
02-27-2009, 10:13 PM
#35
Its Beer Thirty
Just get one from the junkyard man. Just go in and take the cluster apart. Get the clear plastic with the black part attached to it. Shouldn't be more than $10. They give shit like that away at the junkyards here. But if you tried to get the whole cluster they would try and rape you for like $200.
Originally Posted by Daytona
02-27-2009, 10:46 PM
#36
I'll probably do that then.
