04-05-2009, 07:09 PM
#21
Canada's Ghost
Originally Posted by Atmosphere
Where did you purchase yours and for how much?
Right now I'm looking at getting two of these, good choice/site to buy from?
I got them at my local Wal-Mart for all 4 bulbs it cost me just about $90 Canadian. mine were in packs of two, of what looks to be the exact same bulb.
04-06-2009, 02:09 PM
#22
Last question, most of the bulbs I find for my particular model are rated for 55 watts or similar, I'm assuming I'll be okay, right? And they'll still appear white at 35 watts?
These are what I found: http://www.napaonline.com/MasterPage...+Beam+(Halogen)
04-06-2009, 02:40 PM
#23
could #1 also be possibly a bad strut mount? i know my rear right rattles like a bitch and pretty sure its because of a bad mount
04-06-2009, 02:57 PM
#24
55W will melt your wire harnesses. don't get them!
04-06-2009, 03:21 PM
#25
Welcome to the site::
Bulb wattages max:
Low Beams : 55
High Beams : 65
Fog Lights : 37.5
Get Silver Star bulbs, Correct wattage and look great, Fog light bulbs are not made for our fog lights, but get the SS 893 Bulbs, correct wattage, just a different boot. They fit, I put them in my car 2 weeks ago.
Fuel door problem? No problem. Just take the fuel door off, it's held on by 2 10mm bolts (you can see them when you open the fuel door) and yes use WD-40 on the hinges inside the fuel door. Open and close the hinge a few times, reinstall. I did it about 3 years ago, It's starting to not close all the way again so I might have to redo it.
O yeah COME TO ASS!!
04-06-2009, 03:35 PM
#26
You got beat by an Alero!
welcome to the aleromodding family
04-06-2009, 06:17 PM
#27
we have 35W lights. don't go higher, it'll melt things....important things.
Originally Posted by Redog
Low Beams : 55
High Beams : 65
Fog Lights : 37.5
Why do these conflict? I'm thinking about making a quick trip to NAPA right now, but I don't want to buy the wrong bulbs seeing as they won't take back electronics.
Thanks.
04-07-2009, 12:15 PM
#28
The Aleromod PITA
Thanks for all of your advice and ASCII. The gas cap seems to be alright though the rubber seal seems to be a bit stiff; where should I look for a replacement? This is all I've found so far.
Also, where might I look for some decent white/halogen bulbs? I'm not looking to blind anyone, I just think the white light looks much nicer than the factory yellow. So far I've been looking here, but I'm a bit confused with the different voltages, wattages, and kelvin temperatures. I certainly don't want to melt my headlights away.
autozone
04-07-2009, 12:16 PM
#29
The Aleromod PITA
Bulb wattages max:
Low Beams : 55
High Beams : 65
Fog Lights : 37.5
napa grease might last longer then wd40
04-07-2009, 12:43 PM
#30
replace your gas cap, dude. they go bad over time.. the rubber cracks and stuff.
And I wouldnt recommend guessing around at the supposed suspension rattling noise, that could just be a huge waste of money. get it checked out. At a 100k miles it could be among a number of components or bushings.
04-09-2009, 11:15 PM
#31
Yeah now I'm confused...'cause I just changed my headlights the other night...I took the old one in the store with me and it was a 55w...I replaced it with a 53...everything seems normal...no melting or anything...
04-09-2009, 11:32 PM
#32
suspension rattling is likely a bad strut at that miles.
evap leak, put on a new gas lid. and check the purge canister to make sure its ok, mines broke
