05-17-2009, 11:58 PM
#21
do you hear the fuel pump kick on when you turn the key? you could have a shot fuel pump
05-18-2009, 12:06 AM
#22
Originally Posted by Caboose73
ya the pump comes on
_____
05-18-2009, 12:22 AM
#23
relax chief i was just checking to make sure things didnt change
05-18-2009, 12:23 AM
#24
relax chief i was just making sure you didn't skip over that
05-18-2009, 03:48 PM
#25
To sum it up it cranks but wont turn over i changed the plugs,coils,took out my msd coils and went back to the boots,new ICM,fuel pump turns on and runs,new crank sensor,tryed the passlock thing and nothing has worked so i threw in the towel and sent it to the shop and its been there for 4 days now and they dont know whats wrong with it yet
05-18-2009, 04:11 PM
#26
The Drunk
Did you change the fuel filter? cuz they kinda last until they clog up.
`03 Alero GL 2.2L Ecotec
05-18-2009, 06:00 PM
#27
Nope i forgot about that ill give it a shot thanks
05-18-2009, 06:45 PM
#28
just because the pump whines when you turn they key dont mean itll keep up with the engine when its moving, find and hook up a fuel pressure tester on it and make sure its right, also check you fuel pressure regulator. on the other hand, if your dum
but on the other hand if you are dumping fuel or there is alot in the cylinders you should have a spark problem, also MSD systems seem to be pretty unreliable around here atleast, a buddies 302 went through 4 msd boxes so far so try stock and see what happens
05-18-2009, 07:50 PM
#29
I take it it if at the shop they hooked it up to OBD?.Have you held the spark plug wire just off the tip of the plug to see if they actually sparking?..Also i see you took off the LIM,so mabey a compression test might help you.
05-18-2009, 08:08 PM
#30
there's no lower intake manifold on an LD9
like above, fuel filter or check the spark plugs to see if they're really sparking (crank engine with fuel pump relay removed so you don't puddle up a bunch of fuel in the cylinders while testing)
05-18-2009, 08:11 PM
#31
I hooked up my scanner and there were no codes and i only had the msd coils not the dis box but i did switch back to stock just to make sure.They checked the fuel pressure and it was fine so i guess my filter and pump are ok
05-19-2009, 05:32 PM
#32
Fml
well its fixed $446 later it was just a blown fuse going to the ICM which i some how missed when i checked the fuses but at least i did some preventive maintenance replacing the crack sensor,ICM,plugs,wires,fuel filter and msd coils
05-19-2009, 05:59 PM
#33
05-19-2009, 10:12 PM
#34
lolz told ya it was a fuse from the begining
05-19-2009, 10:26 PM
#35
noice work.
when we say check fuses... we mean PULL EACH AND EVERY ONE AND CHECK FOR CONTINUITY!
05-19-2009, 10:29 PM
#36
I did i pulled every fuse and some how i missed it.It took the shop 5 days to figure it out
