03-16-2010, 04:49 PM
#21
other bearing? since you replaced only one?
also... no problem thread jesusing your OWN problem. it gives us previous info to work off of.
03-16-2010, 07:23 PM
#22
it could be cherry. but i replaced the other one in june. only months ago. so i assumed it should still be ok. (and i would pay a mechanic to hook up the tech tools to it, but the abs wire is broken, so it doesn't help anyways)
and when the one was going, it would stay off till i hit a bump or something. now it just stays on constantly.
03-16-2010, 07:50 PM
#23
If by ABS wire you mean the wires goin to the hub.. fix it, that would cause the brake light.
03-16-2010, 08:12 PM
#24
abs wire is broken? that sounds like a dead ringer right there.
03-16-2010, 09:11 PM
#25
true... but the wire has been broken and disconnected for a month or two now. sorry i forgot to mention that.
and the only way to fix it is going to a wrecker and getting a new one lol
03-17-2010, 10:00 AM
#26
well, you half way there!!.... you already know what to do, now go do it!!
03-31-2010, 09:39 PM
#27
alright guys. heres an update.
i looked. both front abs wires are broken. well passenger side abs wire is broken, and the actual connector on the wheel bearing on the driver side got ripped off. so i guess i need to replace a 4 month old wheel bearing. stupid thing.
so until i have $200 for a new wheel bearing. can you disable the whole abs thing so it doesn't look at the wheel bearings and use the abs wires anymore. like pulling the fuse or something.
i plan on driving 1500km this weekend, and would really like my cruise back lol
