10-29-2009, 08:25 AM
#21
ok so yeah im got an hour and a half everyday that i dont have to do anything during school because i have a free block. I will get on how stuff works then if i have any questions after that then i will ask.
10-29-2009, 09:10 AM
#22
Ok so on this page of the How Stuff Works:
http://auto.howstuffworks.com/supercharger4.htm
it makes that super look alot like a turbo? Is that just a picture showing what a super does and its a bad reference, or is that an actual super?
Also, can you like twin turbo a car and then still have a super on it?
10-29-2009, 09:12 AM
#23
Thats a procharger, it's a s/c that looks like a turbo
10-29-2009, 09:19 AM
#24
ok so i just finished reading about turbos.
So it said something about carbs and EFI. so is it easier to turbo a car with a carb rather than EFI? or do the computer tuning process make that easier?
10-29-2009, 09:51 AM
#25
http://auto.howstuffworks.com/supercharger3.htm
an’t get enough turbo and supercharger knowledge? Then you need to get Maximum Boost and Supercharged, by Corky Bell. These definitive, hands-on books on supercharger and turbo system theory, design and application provide the expert advice you’re looking for. With over 25 years of experience in designing, building, and installing turbo and supercharger systems, Corky Bell covers every aspect of creating pressurized induction systems. Whether you want better passing performance, or an all-out horsepower assault, these books will give you all the knowledge you need to get the most out of your engine. These books provide a depth of knowledge and insight only obtained through 25 Years of industry experience.
pair one of these books with a good calculator and a lot of scratch paper, because they are really in depth.....trust me.......
10-29-2009, 10:03 AM
#26
So adding a super or a turbo, it increases horsepower, so what would you do to increase torque?
because you can have a lot of horsepower but if you dont have much torque it doesnt mean much, right???
10-29-2009, 10:07 AM
#27
supercharger and turbos will add torque too.....
Originally Posted by rida125
So adding a super or a turbo, it increases horsepower, so what would you do to increase torque?because you can have a lot of horsepower but if you dont have much torque it doesnt mean much, right???
torque is nice, but i can show you plenty of 4 cylinder cars that have a really bad hp to tq ratio that run 10s or faster.....
10-29-2009, 10:18 AM
#28
I'm just checking here, torque is the power from the engine being put the the street? its the measurement?
Also when you have an FI engine you take out the stock intake, or do you build around it?
Also with camshaft tuning i read about a little. What exactly do they mean by tuning that. Wouldnt it stay the same, or what exactly are they doing to it when they say tuning?
How many Valves does each one of the Alero's cylinders have?
When people put supers on to there car is it needed that you replace your stock cams with perfomance ones so that they are able to work faster or harder for all the extra pressure then?
Do valves need to be replaced with performance ones then?
10-30-2009, 12:46 PM
#29
Bump anybody know
10-30-2009, 01:15 PM
#30
My 2 cents worth....
Superchargers (and probably turbos) DO add torque along with horsepower. Specifically, with the GM S/C on the 2.4L the torque increase is enough to cause some troubles with the tranny (sadly Malibus only came with auto) in 1st gear (slip/chatter) but 2nd on up are very strong (no 1/4 mile racing). The nice thing is that the torque and HP come on immediately, even at low RPMs.
Torque gets you started and HP keeps you moving.
The intake question is answered by 'depends'. With the GM S/C kit the intake is actually built in to the casting for the S/C so it replaces the factory intake altogether. With a turbo setup you have to run tubing for the air coming out of the turbocharger to go into the existing intake system, whether this is replaced with 'better' components would be a seperate issue.
Camshaft tuning involves rotating the camshaft away from the 'normal' timing position, this requires special camshaft drive gears that have adjustable locking points built-in (hard to find if not impossible - some guys build their own). The idea is to alter the timing of when the valves open to allow for improved airflow. It's probably more beneficial to find cams with a longer 'duration' and higher 'lift' which provide for more airflow. Note that this can be very tricky to do properly and can cause other troubles...
The 2.4L engine has 4 valves per cylinder. I don't have a V6...
The GM S/C kit retains the original cams, valves and springs but it doesn't raise boost much - to stay in warranty. It can easily be made to do more with different pulleys to drive it. So nothing special is required BUT I'm gathering parts for a real S/C build (secret cams, p&p head, oversize valves with beehive springs, etc...) as I know this motor can do much more.
Main thing to watch for is sufficient fuel flow. Any boosted engine that runs too lean for any reason will overheat internally and cause lots of trouble. Luckily for me it was just shattered rings....
Most of my comments may not apply to your car, as far as I know there is not any real S/C available for the V6s. Good luck and keep asking questions until you feel that you understand, that's how you learn.
10-30-2009, 02:32 PM
#31
Thanks for that. Yeah I don't have the money to actually do any of this to my car but I just wanna learn about these, and I can't be the only person on here on this website that wants to know more.
So with the valves and cams the thing you want with those are being able to let more air into the cylinders?
Does anybody know how many valves per cylinder the V6 has?
10-30-2009, 03:19 PM
#32
The 3400 SFI
3.4L Pushrod LA1
60 Degree V6 12 Valve
2 Valves Per Cyl
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
10-31-2009, 01:10 AM
#33
Ok so what you guys prefer Supercharge or Turbocharge and why?
10-31-2009, 02:09 AM
#34
Canada's Ghost
depends on how you look at it some guys will say super because it's instant boost but others will say turbo because they are able to control boost.
10-31-2009, 02:10 AM
#35
If you want to go fast the go supercharger but if you want to go really really fast go turbo it all comes down to personal preference and how much time/money you have to throw into the project.
10-31-2009, 08:08 AM
#36
supercharger, because i like to whine.......
10-31-2009, 07:41 PM
#37
Explain yourself
10-31-2009, 08:44 PM
#38
turbos "pssst"
supers "whhaaaaa"
its just how they sound.
10-31-2009, 10:37 PM
#39
I prefer twin turbo.
2002 Oldsmobile Alero GL 1990 Nissan 300zx n/a 1991 Nissan 300zx TT
10-31-2009, 11:44 PM
#40
twin turbos are overrated, you can make just as much and usually more power on a big single turbo, why is it that supra guys almost always switch from twin to a big single?
check and mate.......
