03-24-2017, 07:05 PM
#21
Originally Posted by Babyblue
Thanks! it kills me to see these new parts sitting around and not on the her...But When I don't want to start replacing stuff till I have every piece to the puzzle.
You sound like me but then i get impatient and half ass stuff then have to redo it to get it right... My car is half torn apart again to fix things and hopefully get her out again this spring for a few trips then get down to work on finishing everything... The goal is to have her back to one colour before next winter...
03-25-2017, 08:09 AM
#22
Gonna ride smooth as silk when it's all said and done.
03-25-2017, 12:43 PM
#23
I can't wait to see the finishing product!
That's the plan!
Just a small update...I jacked up the rear end and started spraying the bolts holding all the suspension parts with pb blaster to break some of the rust down on the bolts. I decided to take a look at my parking brake cables because the driver side doesn't seem to hold when the brake is up. From what I saw, the cable is seized and doesn't do a thing when the parking brake is up or down. So I went ahead and ordered two new cables, because why replace just one?
03-26-2017, 08:10 AM
#24
of course. Might as well replace both while you're under there doing everything else and all the suspension pieces are out of the way.
03-27-2017, 01:30 AM
#25
It'll be fun. I'm doing all those parts + calipers tie, rod ends, fuel pump, valve cover gasket, so on on the intrigue. It's so much easier to work on than the alero. Sway bar bushings are easy to get to go to, took 20 minuets for them all. I have access to a hydrolic press and drill press at work so I replaced the ball joints and bushings on the control arms. Never again, you were smart just getting new arms.
03-27-2017, 07:51 AM
#26
I'm really excited to get started. Just need the rack and some sway bar bushings in the rear. Money is a little tight after buying all those parts so I have to wait to buy the rack. Also it would be silly to put in all those parts and not replace the rack..The car has 235k on it and that rack looks like it has about that many miles on it too. But I wanted to polish my aluminum control arms and insert new bushings from babyblue and use them. I started a new shift at work so I'm finding it hard to make time for myself lately. When I do start working on her and replacing all the parts I will be posting TONS of pictures of before and after, and the car itself etc.
03-28-2017, 07:29 PM
#27
Got the new parking brake lines in! I might just put these on this weekend with the rear wheel bearings, rotors, and pads. Get a little jump start on the project.
04-03-2017, 01:51 AM
#28
04-03-2017, 08:30 AM
#29
Those laterals look toast!!! Are you upgrading to the w body rear lateral arms? I got mine off rock auto for $130 cdn shipped to my door... Just a thought since you're upgrading everything
04-03-2017, 02:36 PM
#30
I did order some and I just went with stock for now.
04-18-2017, 08:06 PM
#31
04-18-2017, 08:07 PM
#32
A picture of her the other day after being cleaned up a little,
And just for the fun of it a picture of my two favorite dogs..
Raven
Magnum
Well there ya have it! the whole suspension is replaced front and back! after getting her alignment it was a joy to drive down the road. I'm looking forward to starting my next BIG project on this car. It makes me happy to be able to bring one of the final 500 back to life again!
04-19-2017, 09:48 AM
#33
Nice job Parker!!!
So what's next?
04-19-2017, 11:40 AM
#34
Nice job Parker!!!
So what's next?
I would like to get interior cleaned up. But engine wise exhaust. I'm gonna try to get that done in the next few weeks.
07-10-2017, 03:35 AM
#35
I know what you mean about the rack. I replaced mine shortly after the homecoming you brought the blue one too. When I installed the non-exsistant front sway bar I ended up taking it back out to slide the bar in, then re-stalling. I'm over doing work like that. I also replaced a trailing arm bent like yours, what on earth were people doing with these cars!
Looking good
07-10-2017, 06:53 AM
#36
Looking good
People think the trailing arm and the lateral links are good pull points to get out of a situation where they are stuck. I see it all the time. I had to replace a lateral link on my Alero because of this. Driver rear one. Funny thing is, the aftermarket link is thicker and has a better bushing than the factory one.
07-05-2018, 08:21 PM
#37
First of all lemme tip my hat to u sir. That's an amazing amount of work and it looks sooo clean I'm so impressed. It's exactly the project I've been attempting for a year and a half LMAO. I was wondering what brand of struts u went with. I also have the quick strut my fronts are Moog Problem Solver. I was gonna do the whole suspension in Moog Problem Solver. Good idea? Bad idea? Suggestions please. Thanx!
