Old 11-21-2004, 10:28 PM   #21
sl3196
Originally posted by Alero-+Nov 21 2004, 09:12 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (-Alero- @ Nov 21 2004, 09:12 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-sl3196@Nov 20 2004, 11:51 PM
Then just do everything in the opposite order. Reconnect all hoses and fill the radiator (overflow tank) with straight coolant. Warm the car up to operating temp and then open the bleed valve(s). Leave them open until coolant comes out and then tighten them back down. Recheck coolant level.
http://www.sourcenet.ca:9001/servlets/Blob...mspsdsubkey=826
what!? i drain the coolant then fill it up then drain it again!? [/b][/quote]
You drain it, flush it, fill it up again, and then bleed the cooling system. Read the link if you don't understand my directions.
Old 11-21-2004, 10:54 PM   #22
-Alero-
-Alero-'s Avatar
your link doesnt work
AUTOBOT
Old 11-22-2004, 04:15 AM   #23
sl3196
http://www.sourcenet.ca:9001/servlets/Home
Put in your info and then find the instructions for the thermostat. Can't be any easier.
