10-22-2004, 01:15 AM
#41
So those Philips bulbs arent actually available in stores anywhere? Screw that then, I'm not paying shipping for some simple headlight bulbs <_<
Edit: forumula is right, any time there is any sort of coating on the bulb, it takes away from the actual brightness of the bulb (that sparkly coating on Silverstars included). But that's fine, because the Silverstar's are still a bright white color to the naked eye and thats all I'm really looking for...
Double Edit!: formula, do you have said Philips Vision Plus bulbs? And if so, we need some pics please kthxbye
10-22-2004, 01:27 AM
#42
Originally posted by Alero-@Oct 16 2004, 12:04 AM
if you want a blue bulb and i mean blue as hell, get Nokya, had em for over a year and havent had a single problem with em, and they are 7000k on the kelvin scale, and are 80 watt bulbs. very nice IMO i belive i bought them from autodirectsave.com they got alot of nice bulbs, i bought a majority of my LED's and nokya lights from them. they were definatly worth the money, trust me :thumbsup:
Do you have a link to where I can get them ??
10-22-2004, 02:56 AM
#43
The Founder
Yeah, I had those Nokya ones as well. I got them off ebay like 2 years ago. They actually lasted me much longer than my Eurolite bulbs, but still eventually fried the harness. I was sort of impressed with they way they looked though, and they did last longer than other high watt bulbs.
10-22-2004, 08:48 AM
#44
I got Nokya's too, but mine are 55W and the box says 75W silulated. I hope my harnesses will live. What bulbs did you have Nick?
Weird they make to Wattages for the same size bulb
2010 WRX 265 - AWD Boost
2004 RX-8 GT - Gone
2006 Cobalt SS 2.4L VVT - 15.05 @ 94.91 - Gone
1996 Camaro Y87 - Gone
2003 Alero 2.2L GX 5-Spd - 15.21 @ 88.21 - Gone
10-29-2004, 06:02 PM
#45
Hey Alero,
I went to the autodirect.com page and found blue Nokya bulbs, but which one is for the Alero? They have: (see: http://www.autodirectsave.com/Nokya_Xenon_Pro.asp)
H1
H3
H4 = 9003
H7
H8
H9
H10
H11
9004
9005
9006
9006 XS
9007
893/899 = 880,890,885
Help please?
10-29-2004, 06:49 PM
#46
Bubba
in the future please read the entire thread, or at least use the search function.
as i said in the second post in this thread
10-29-2004, 08:42 PM
#47
I read the thread, but from what I can gather, the Philips vision plus bulb doesn't give off blue light (sounds like beer to me :P ), am I correct?
10-29-2004, 08:50 PM
#48
i was referring to what i set in bold type.
you asked which bulb size, and i told you. ignore the phillips stuff if you want nokya
10-29-2004, 09:14 PM
#49
Naich, did you get the same bulb as MAlero?
MAlero «I got Nokya's too, but mine are 55W and the box says 75W silulated. I hope my harnesses will live. What bulbs did you have Nick?
Weird they make to Wattages for the same size bulb»
Like; I also do not want to burn my harness.
10-30-2004, 02:08 AM
#51
did you ever try upgrading your harness with the eurolites? Or do you know someone that has and had good luck doing so.
A.K.A. sepultribe66
the alero will be missed :o(, but I love the mazda6 :o)
10-31-2004, 01:16 AM
#52
if you want your head lights to glow blue get the blue neon insert for your head light.
10-31-2004, 10:58 AM
#53
Where do you get the blue neon inserts? Thanks
10-31-2004, 11:51 AM
#54
The Founder
You can't really "upgrade" your harnesses per se. I bought the beefiest ones I could find after trying a few auto parts store. They all melted. The problem is this.... the bulbs get much hotter than stock bulbs, and the harnesses are simply not designed to handle it. Some of the "better" blue bulbs out there actually have carbon or carbon fiber bases, which don't melt like plastic. I had to replace my harnesses at least 5 times that I can count, and I got harnesses from lots of different stores.
My bulbs were also marked 55w with 75w also on the packaging, bubba. I would definately consider getting those phillips bulbs or silverstars.
10-31-2004, 11:56 AM
#55
Thanks Naich. I am all thumbs when it comes to mechanics, so burning out harnesses isn't an option for me, so I appreciate feedback. Of the two, Philips or Silverstar which one would you recommend. Thanks again.
10-31-2004, 02:08 PM
#56
thanks for the info naich
A.K.A. sepultribe66
10-31-2004, 02:43 PM
#57
well lets just say they are comparable.
one is 20 bucks
the other is 40
the 40 dollar one is easy to find at walmart or in any auto store
the 20 dollar one may have to be ordered online.
so its basically up to you. there's no real way to say HEY this one is better. i've read in multiple places that the phillips puts out 30% more light because they dont have a color filter coating on the bulb, but that same color filter makes the light output APPEAR white/blue to the eye.
11-01-2004, 06:35 PM
#58
Originally posted by Naich@Oct 11 2004, 08:14 PM
and where does it say it is DOT certified?Â;-) As far as I can tell, these are European spec.
Naich,
I had my doubts too about Philips Vision Plus not being DOT certified, so I wrote the vendor, and this is the answer:
«yes (they are DOT certified) we would not be able to sell them in new york if they were not»
So, they are DOT certified, at least in the state of N.Y.
I also wrote the vendor of the HIR headlights http://hirheadlights.com and got this answer:
«Hi, (Bubba)- Yes, they're both DOT legal, and it is cast into the base of the
bulb at the Toshiba plant. No heat issues with these bulbs, either- they run
at stock wattage, 55W and 65W. So far, they've mostly been installed in BMW
8 series cars, which are sensitive to heat, and no problems at all. That
includes 6000 miles use in my own car.
Thanks for asking,
Bill Fox aka Max Lumens»
So, as I understand it, Silverstars, Philips and HIR's and all DOT legal!
11-01-2004, 07:52 PM
#59
good research bro.
11-09-2004, 08:45 AM
#60
From the blue headlights but, I gots me a pair of the Philips Vision's on the way should be here in 3 days, then ill get a compaison photo with my silverstars.
My drivers side headlight went out, so instead of replacing it with another ss for $20 ill get a pair of these for the same price
