05-21-2006, 10:07 PM
The other day I took apart the dash to paint it now I have put everything back together and all the gauges on the display wont work they light up dam even the check engine light went on but the rest doesnt work
I know when I took apart there was only one wiring harness at least im pretty sure it was one some one any one please help
[font=Arial]<span style=\'font-size:8pt;line-height:100%\'><span style=\'color:red\'><span style=\'font-size:12pt;line-height:100%\'>
2001 alero cleared corners ,custom dual exhaust ,red neon under glow kit
Peace to all my brothers from a diffrent mothers and all you ladies keep lookin beautiful
ALLHEAT</span></span>[/font</span>]
05-21-2006, 11:07 PM
Did you fully remove the dash? What harness did you play around with? There is more then one harness behind the dash. Please expain in detail what you did.
05-22-2006, 12:25 PM
I fully removed the dash and i know there is more then one harness I hooked everything up to the right place I hope and when I pluged in the cluster for some reason none of my gauges work the all light up and the only light that comes up when you start the car is the check engine light but goes away as soon as the cars started
05-22-2006, 01:21 PM
check the fuses.
05-22-2006, 02:27 PM
Please tell me you unconnected you battery when you were messing around with the harnesses...
Like Molson said check the fuses but also when you plugged the harness back into the cluster did it click? Have you removed your cluster and tried installing it again?
05-23-2006, 10:33 PM
sh!t you know what I didnt remove the battery cables is the cluster fried now
05-23-2006, 11:02 PM
i think it would be fine, ive connected and disconnected my cluster while my car was RUNNING.
05-23-2006, 11:08 PM
ya not having the battery connected isnt gonna made a difference.
id check to make sure that the plugs are actually plugged in all the way.
by the way...... do you still have those visonik subs for sale?
joelsoundxtreme: u faggot
05-24-2006, 07:52 AM
Check the fuses...I had the same thing and it was a fuse in the pass. side dash fuse box- a completely unrelated fuse, so just test them all. Good Luck .
05-25-2006, 12:20 AM
Commanche do you know what fuse it was cause i tested all the mini fuses is it one of the bigger ones or a relay
05-25-2006, 02:59 AM
its the cruise fuse in the passenger side fuse panel or it should be. if thats not blown then ur got a problem for them not to be working. the cruise fuse ones a 2 amp and 10 amp .. its the 10 amp one. When i got rid of cruise control.. i thought i didn't need that fuse but apparently i did for the gauges to work.
05-26-2006, 12:02 AM
ok found it it was the fuse on the drivers side hidden under the relays you know the 3 on the bottom marked ips/hvac batt any one know what that means
