Old 08-30-2009, 03:29 PM   #1
Resistors
Heres a little info for the guys who play with leds.
http://physics.bu.edu/py106/notes/Circuits.html
http://www.1728.com/resistrs.htm
As your led setups expand, you may run into the need to have a high wattage resistor, but with the standard supply for resistance.
Your average resistor is 1/4W or 1/2W. An average led runs 0.072W @ 3.6V. If you wanted to run more leds in parallel off one resistor, you would need a higher wattage resistor
After fiddling with Ohm's law a little... I came to this answer.
Problem: You need X Ohms @ Y Wattage
Explanation: Wiring resistors in parallel will cause the resistance to be 1/R (x being your resistance) [use the calculator above]
So? for every pair you have in parallel , put a pair in parallel behind it, and you'll stay at the same resistance.
Matching the number in series, with how many resistors you have in parallel, and you'll always end up at the same resistance.
Examples: using 470ohm 0.5W resistors
1/470+1/470 = 235ohm @ 1W
...combined with another in series...
235Ohm + 235Ohm = 470Ohm @ 1W
1/470+1/470+1/470 = 156.67ohm @ 1.5W
...combined with 2 more in series....
156.67Ohm+156.67Ohm+156.67Ohm = 470ohm @ 1.5W
Old 08-30-2009, 03:35 PM   #2
yet another calculator to simplify things...
http://ledz.com/?p=zz.led.resistor.calculator
Old 08-30-2009, 03:39 PM   #3
neat! thanks!
Old 08-30-2009, 04:09 PM   #4
hok666
nice Ill check it out later..
Old 08-30-2009, 06:30 PM   #5
i personally use 1 resistor wired directly to each led instead of multiple leds of of on resistor. simplifies things for me when it comes to expand. pretty neat calcs u found btw
Old 08-30-2009, 07:31 PM   #6
this would benefit if you had... say... 8 wired in parallel to a circuit board, and wanted to replace them.
Old 09-06-2009, 02:17 PM   #7
ok. while my logic does kinda sorta work... it doesn't apply for the situation.
several leds in series need to have the current taken into account. CORRECTLYusing the VIR equation yields... 63.75 ohm @ 1.63 amp.
so...
using a 270ohm 1/2W x4 (in parallel) will give 67.5ohm @ 2W.
I'll test this idea soon... but not terribly soon. Gotta find time/parts
Old 09-06-2009, 04:20 PM   #8
check out this site.... it has almost any 12 volt calc you will ever need.
www.the12volt.com
Old 09-06-2009, 04:29 PM   #9
oh i definitely have that one bookmarked too.
but it doesn't help with the more advanced stuff.
