Old 05-26-2010, 10:34 AM   #41
zzyzzx
zzyzzx's Avatar
Those RPM pics looks like thay match mine.
With that many miles on the car I'd clean ir replace the Idle control valve if it hasn't been repalced already, clean the throttle body and EGR lines and valve.
Old 06-07-2010, 12:51 PM   #42
Well found out what the problem was:
http://www.aleromod.com/forums/showthread.php?t=31572
Fuel filter was clogged. Fuel pump was working hard.
Runs like a champ now.
Old 07-06-2010, 01:28 PM   #43
^ Must be the humidity.
A couple days after that post it started doing it again...
THis weekend I bought a bottle of Trans X. Supposed to clean/free sticky solenoids, freshen up seals, etc. Genie in a bottle.
As of this post seems to be well worth the $5...
No more lope (as of yet). However I thought I had this issue fixed before... So only time will tell.
Old 07-06-2010, 03:03 PM   #44
zzyzzx
zzyzzx's Avatar
Just read in another forum where someone had a dropped valve seat and was blaming the transmission for that too.
Old 07-06-2010, 03:23 PM   #45
I wonder if this could be the problem with the wifes Tarus...I'll have to check into this. Hell I know I need my filter replaced too...How much did it run...just to get an idea.
Old 07-06-2010, 03:33 PM   #46
Filters run about $15, $10 for trans fluid or so.
Its kinda a messy job. So make sure to have ample cardboard down under your work area. Also two oil pans handy.
