10-16-2009, 01:20 AM
Canada's Ghost
N-body ecotec motor Mounts
Does any one know where I can get motor mounts for the ecotec or if there are mounts that will work with the ecotec powered N-body?
10-20-2009, 07:29 AM
You have a automatic correct?? If so this should work
http://www.milzymotorsports.com/miva...Co de=NbodyTM
Now for the Upper motor mount theres NONE so far. But this one is pretty close, basicly for us ECOTEC we need the "Motor to Mount" plate made. And actually from his description, we would need the bottom plate since his not selling it(means we need a use 3400 or 2.4 one)
http://wot-tech.com/shop/all/1999-n-.../prod_222.html
10-20-2009, 08:09 AM
$185! Damn!
You can just fill your stock trans mount with 3M Urethane for about $8 I think.
10-20-2009, 01:10 PM
Canada's Ghost
sounds sketchy
11-11-2009, 03:49 AM
Canada's Ghost
so is a lower mount the same as a trans mount or are they two seperate types of mounts like I think they are? I found a lower mount for the grand am on Rk sport for $45 http://www.rksport.com/main/part_det...id=9&catid= 3 they don't give much info on it...
11-11-2009, 08:25 AM
We dont have a lower mount tho... especially not like that in that picture. That is the one on the cavalier which is way different engine craddle than ours. That wont even fit a grand am, if is that one on the picture. Ill try getting some pictures later.
11-11-2009, 09:01 AM
Wide Open Throttle
How much different is the ecotec side mount compared to a 2.4 or 3400?
11-11-2009, 12:18 PM
Well your mount fits the chasis perfect, since we can swap any motor in it. The difference is the mount to motor plate, we would need one made for that.
11-11-2009, 12:35 PM
Wide Open Throttle
Got a picture of what it looks like?
11-11-2009, 06:03 PM
This is how the stock one looks like, its obviously a different design than yours:
This is the one they sell for the j-bodies, its a closer design to yours. I believe the dimensions are not the same, like the two bolts that holds the mount to the chassis.
Also their motor adapter is different than n-bodies, compare the bolts.
11-11-2009, 09:29 PM
damn thats one shiny cover... wish i could get mine like that
11-12-2009, 06:16 AM
Wide Open Throttle
The stock 3400 plate wouldn't match up to your block side mount?
11-12-2009, 08:00 AM
I doubt it, looks kinda close with the 3 holes design, but for some reason I think is shifted the opposite way. I looks like the third hole is farther out.
I been looking for a cheap or free mount to try. Heres a better angle.
11-18-2009, 02:55 PM
The Aleromod PITA
when mine broke they got it from a gm dealer, wernt cheap
11-18-2009, 04:15 PM
Nothing on rksport fits the n body
11-18-2009, 05:38 PM
Canada's Ghost
I want stiffer mounts not replacements.
then they should stop selling it... I didn't buy it but it got me thinking.
so I take it I'm stuck with stock ones for now. darn! lol
11-18-2009, 05:50 PM
U aint the only one lol... theres so many ECOs and this guy is one step away lol.
11-18-2009, 06:00 PM
Canada's Ghost
yeah I wanna get everything ready so I can get the most out of my "big" mod when the time comes for that.
11-18-2009, 06:15 PM
What you doing? lol
11-18-2009, 06:48 PM
I'd also like one to work on something besides the engine. The lack of it has actually made me wonder if doing it how ion said will work for the upper mount. I would prefer to do it right, but nothing is available.
