Old 04-21-2009, 02:55 PM   #1
kevin1114
kevin1114's Avatar
kevin1114 is on a distinguished road
Flashers
Hey everyone,
for a coupling of weeks now i 've benn having my flasher only work part of the time... and now i can hear the relay clicking even if the flasher isnt on???
Whats happening and can i fix it myself?
Thanx
Take Life's Curves Sideways, and Drift!
kevin1114 is offline   Reply With Quote
Old 04-21-2009, 02:56 PM   #2
shez
shez's Avatar
shez is on a distinguished road
Send a message via AIM to shez
flasher?
do you mean the hazards?
shez is offline   Reply With Quote
Old 04-21-2009, 02:58 PM   #3
colonel6632
colonel6632's Avatar
i think he means when he signals... sometimes they don't light up... but he can here the clicking noise the relay makes
Old 04-21-2009, 03:05 PM   #4
Isn't this problem due to a bad hazard switch...use the search button I think this issue has come up before.
Old 04-21-2009, 03:07 PM   #5
it's the most common problem because it's a recall.... everyone has it though even if your car isn't covered by the recall.
Old 04-21-2009, 03:09 PM   #6
shez
shez's Avatar
yeah. i had to jiggle my hazard switch in order for my turn signals to work. just replace the hazard switch. i did that and everything was fine.
Old 04-21-2009, 03:22 PM   #7
did you check your blinker fluid? lol j/k
I had this issue as well. Got the part from gmpartsdirect.com . Takes a good 20 minutes or so to install... Solved the problem and they work fine now.
