04-25-2005, 05:39 PM
Does anyone know if you can put the 5 speed manual transmission on the 3.4 liter engine? and if not, can I get a manual tranny that will work.
04-25-2005, 06:12 PM
talk to springs he can help you out
04-25-2005, 07:01 PM
Senior Member
yeah, but the problem with talking to springs is to do it like him, or the general idea, you need to have a big wallet
04-25-2005, 07:20 PM
Oh boy, here we go again! Have fun, and that's all I'm going to say. If you want a fast manual car, go buy a civic or something. They can be fast for half the price of putting a manual tranny on the 3400 (it's not a 3.4, unless you have an Impala or Monte).
04-25-2005, 07:36 PM
i suggest swapping motors, that are actually compatible with a manual. liek the 2.2 with the 5 speed
AUTOBOT
04-25-2005, 07:37 PM
it is not that he does the expensive stuff it is that he does it the right way to assure maxium performance and reliability, and that does not always come cheap
04-25-2005, 08:02 PM
very well put mike.....
04-26-2005, 12:00 AM
There are 5 manual transmissions that will bolt to the 3400
1) Getrag 282
2) Getrag 284
3) Isuzu
4) Getrag 287
5) FGP 40
The FGP 40 would be best but seeing as that isn't out yet (it will be the 6-speed in the G6 GTP). The easiest one would be the Getrag 287, as it's the stock 5-speed in the alero, you just need the "M94" version that was installed in 2000-2002 Cavaliers and Sunfires with the 2200 OHV engine.
The Isuzu isn't recommended, because it was used on the lower output engines and probably wouldn't take too well to all the torque of the 3400. The Getrag 284 is a good transmission, but parts availability is nonexistent, and supposedly the pull-type clutch causes excessive wear on the crankshaft. The Getrag 282 is the old standby that most use and it was very popular, however the newest ones are from 1994
04-26-2005, 12:11 AM
Senior Member
are you sure they will bolt right on to the same engine we have, does your beretta have the 3400 drop in?, cause im sure john looked into that and he just ended uo having to make all his own custom parts, but i could be horribly wrong, cause if this is the case then im soon to have a manual transmission
04-26-2005, 12:27 AM
**cough** SEARCH BUTTON!!!!**cough**
04-26-2005, 12:54 AM
1) Getrag 282
2) Getrag 284
3) Isuzu
4) Getrag 287
5) FGP 40
The 287 also came mated to the 00+ 2.4s (sunfires, cavys, GAs, aleros, etc). The isuzu is came mated to the 2.4 from 96-99 and is just considered junk. The 282 is strong as a "brick sh!t house" and came bolted to the 3100 so you figure out if it matches up
I'm on a boat.....
04-26-2005, 07:15 AM
impala never had a 3.4
2001 Alero GLS - Sold!
04-26-2005, 09:06 AM
the four cyl will not bolt up.
you need the 282 but off of the 3100's it bolts right up but custom made brkts and what not will have to be made
04-26-2005, 11:38 AM
Senior Member
so it will work, you just need to custom mount it?..... hmmmm what cars did they come in again?
04-26-2005, 11:56 AM
Originally posted by mike2002+Apr 26 2005, 05:15 AM--><div class='quotetop'>QUOTE(mike2002 @ Apr 26 2005, 05:15 AM)</div><div class='quotemain'><!--QuoteBegin-flalero@Apr 25 2005, 05:20 PM
Oh boy, here we go again!Â;-) Have fun, and that's all I'm going to say.Â;-) If you want a fast manual car, go buy a civic or something.Â;-) They can be fast for half the price of putting a manual tranny on the 3400 (it's not a 3.4, unless you have an Impala or Monte).
[/b][/quote]
Whoops, I thought both the newer Monte and Impala came with the 3.4 as the base motor. Anyway, the easiest option would be to swap in one of the four cylinder motors with a manual transmission. They could be just as fast as the 3400.
04-26-2005, 05:19 PM
Originally posted by flalero+Apr 26 2005, 11:56 AM--><div class='quotetop'>QUOTE(flalero @ Apr 26 2005, 11:56 AM)</div><div class='quotemain'>
[/b][/quote]
^^true hp wise but i dunno about torque wise.
and mike, yes the impala's did come with the xact 3.4 motor as us. offcourse not the new ones but the ones in present day have the 3.4 v6 in them.
AUTOBOT
04-26-2005, 05:28 PM
Yea....the impala out right now does have a 3.4 or 3.8 available for it.....
04-26-2005, 06:39 PM
Senior Member
does anyone know what cars the 282 came in?
04-26-2005, 07:12 PM
Originally posted by 1WhiteOSV+Apr 26 2005, 05:28 PM--><div class='quotetop'>QUOTE(1WhiteOSV @ Apr 26 2005, 05:28 PM)</div><div class='quotemain'>Yea....the impala out right now does have a 3.4 or 3.8 available for it.....
[/b]
the SS one has the 3.8 and the normal one has the 3.4
<!--QuoteBegin-SilverBullet256@Apr 26 2005, 06:39 PM
[/quote]
aparently cars with the 3100 motor, from what i read....i might be wrong.
AUTOBOT
04-26-2005, 07:36 PM
Originally posted by -Alero-+Apr 26 2005, 03:19 PM--><div class='quotetop'>QUOTE(-Alero- @ Apr 26 2005, 03:19 PM)</div><div class='quotemain'>
[/b][/quote]
i know the impala's came with the same 3400 as us, it was a smart ass comment in response to "alero's dont have 3.4's, they have 3400's". 3.4's as in the dohc 3.4 in older w-bodys, that the monte had, but back then there was no impala, the lumina could be had with a 3.4 though
