10-17-2009, 03:12 AM
#21
I use them both for drinks. Hardly ever have any issues..
10-17-2009, 04:10 AM
#22
The one under the HVAC I put all my crap change in (pennies, nickels, dimes). The other one I put my loonies, toonies and quarters in, as well as drinks.
Used to put my cell phone there but I upgraded to the iphone and now I have a dock in the lighter so my phone just sits on that. Not the best looking thing but it does the trick.
10-17-2009, 07:07 AM
#23
The one in the front is my official mp3 player holder, works really well for that because the wire only has to go from the mp3 player to the cassette player.
10-17-2009, 08:38 AM
#24
cellphone
Ipod
gps
and drinks
10-17-2009, 09:14 AM
#25
the front cupholder is NOT for change, that little flip out thing under the dimmer is for change
i use both for drinks, both fit a large drink from burger king just fine
10-17-2009, 10:06 AM
#26
i have the rubber piece and short sized ashtray so every thing fits perfectly and flush ... it looks great kinda sucks tho hard angles to try to ash
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
10-17-2009, 11:44 AM
#27
There is not enough room in that thing for change to stay long-term.
10-17-2009, 11:46 AM
#28
I got a switch mounted in mine ha you've seen it
2003 GX Coupe: 2.2 ecotec, CAI, Header, High Flow Cat, Catback Exhaust System, Cleared Corners, Tinted Tails, 8000K HID's, Reverse Glow Gauges...so far
10-17-2009, 11:47 AM
#29
that is true that is why I use the one behind the shifter for coins and the one with the top for the other things.
10-17-2009, 12:54 PM
#30
no! that little flip out thing is for your bluetooth headset!
10-17-2009, 12:59 PM
#31
In the hole btw the shifter and the console, I have the Ashtray option in my car, theres a rubber socket that kinda "clamps" in the bottom of the whole (theres 2 little holes at the bottom) and the Ashtray fits perfectly in there. I should take a picture of it one day.
thats exactly what I have:
10-17-2009, 01:15 PM
#32
I use the front cup holder as my cell phone holder, the middle console one for drinks, and then the change holder on the left of the wheel for my bluetooth headset. Never tried putting drinks in the front one cause I haven't had the need to yet...lol.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
10-17-2009, 01:24 PM
#33
Wow, I can't believe how many people keep change in their cars. The last time I had change in the car was before the Alero. And before I got a electronic toll transponder.
10-17-2009, 01:32 PM
#34
thats where my trunk button relocated to.. little hidden pushbutton.
10-17-2009, 02:40 PM
#35
i use it to hold my phone and put my mp3 player in i when its plugged in
I am beyond help...
10-17-2009, 02:43 PM
#36
I keep the ash tray cup that came with the car in the front one. There is a holy medal in the cup becasue it broke off the clip.
The rear one. I can't believe how many people are saying that a 20 oz soda bottle will not fit in there. I've had NO problems with a 20 oz fitting in there.
Mine is a 2000 and it has that little door thingy on it if that makes a difference
10-17-2009, 02:59 PM
#37
Ha mines for my foglights...My car didn't have OEM ones so I wired them in myself
10-17-2009, 06:49 PM
#38
That little change cup in my car is, ummm, empty
10-18-2009, 12:40 AM
#39
Originally Posted by Oldsnut
The one in front of the shifter is the coin holder and the rear one will only fit a can or small water bottle. I've been looking for a unit that fits in the smaller rear one and expands to hold my coffee mug.
Or you could get a coffee cup that has the small bottom on it, and then it will fit.
10-18-2009, 09:49 AM
#40
i can keep about 10$ worth of change in that little flip out thing, front thing that usually has an ashtray, i keep my celly in.. and the rear cupholder (1999) has the door, i can fit a 64oz Big Gulp in it
