Ok, this is going to be a long question, but I need help because its driving me nuts! I have not posted here in a while, and I need fellow Alero opinions
All of a sudden my drivers side headlights both high and low beam do not work! I was driving one night and they started flickering, and even my daytime running lights came on at night? The Kicket, the side marker and turn signal do work, just not the hi and low beam! Also, the entire passenger light is fine, everything works! Now, I have a hid kit which has worked great forever. First I ordered and tried new bulbs for drivers side, nothing! Next, I replaced the ballast thinking it was bad, nothing! Then I swapped out and used a known working ballast and bulb.....nothing! The weird thing is that the turn signal and side marker are fine! Next, I checked the fuse box and pulled the little 15 amp blue fuse, it was blown for left head light Assembly! I replaced it with a known working one, still nothing.....WTF! So, I am thinking maybe fog light relay or head light relay switch or bad ground? Maybe dirty connector or short? Why would half the light work, and other half not work? My next step is to get a voltmeter and test and make sure both connections to headlight Assembly are getting voltage? Lastly, where in the fuse box is the relay for the headlights/fog lights! I ordered the relay already, but the number is different then what the fuse box says? Do you guys know what number it is labeled in the diagram?
Any ideas guys...this is driving me nuts!
