09-26-2010, 08:30 PM
Lowering car....questions
Ok well i know i should go with the adjustables....but they are pretty damn expensive. Right now i NEED struts bad and the GR-2's fit my budget so dont go telling me to get the other ones.
Anything will be better than what i have now
I was going to get the springs and struts from andysautosport....but they dont have the "camber adjustment kit" and i want to make sure everything is done the right way. I will be bringing it to this place around here that does good work and has an alignment machine....but i want everything to go smooth no problems. So this camber kit is a must, right?
http://www.pfyc.com/pc/GN4009/ALSUSP...ment+Kits.html
Now, idk which one i need.....is it the first one? there are two different part numbers.....on the bottom it says alero front (measure to be sure)..... so which one will work? idk why it would say that.
But yea 4 struts all around, eibach springs and camber kit....does that sound good? anything else i need? OH i also have polyurethane bushings i wanted them to put on. Got them a while ago...
PLEASE GET BACK TO ME ASAP SO I CAN ORDER THESE!!! :P
THANK YOU!
09-26-2010, 08:51 PM
Eibach Pro-kit springs give a minimal drop and do not require camber-correcting bolts.
I'll assume your poly busings are for the control arms - bushings require a bushing press, and cutting the old ones out isn't easy or cheap, so if you're short on cash you might want to skip this for now.
You will need an alignment though.
09-26-2010, 08:55 PM
Cool! Thanks man. Im not necessarily short on cash....but im on a budget. I will ask how much they charge for the bushings.....i was a little worried about how much its gonna come to....lol....cool, gonna order this stuff now. Im excited to get this bitch lowered finally..... omgosh its been too long.
09-26-2010, 11:33 PM
billy i have kyb gr-2 struts for sale and drop zone springs for sale
would be a great set up
09-26-2010, 11:47 PM
Thanks dude....i forgot u were sellin those struts... but i cant do drop zone....this car is driven year 'round and the eibachs are perfect for what i need. Thank you though....hey i will give you a call sometime....when is the best time for me to call?
09-27-2010, 12:56 AM
i drive my black one year round and the roads here are terrible and lots of snoe on the winter... still i have gr2 and CM that gives the same drop than dropzone...
09-27-2010, 04:23 AM
Didn't think we needed bolts? The dzs really aren't bad snow and ice storms here and never had a problem
09-27-2010, 06:54 PM
don't need bolt if you have the gr2 because the holes for the knuckle are slotted and you have enough camber adjustment only with that... both of my cars are dropped and still on the specs without camber bolts...
09-27-2010, 07:59 PM
after 6pm is best
09-27-2010, 09:00 PM
Drove my car year around on Dropzone springs.. don't be a wimp.
Can't even tell the eibach's drop it unless you line up side by side, dropzone looks soooo good. Buy them all off bdyman.
09-28-2010, 05:12 AM
EIBACH IS NO LONGER MAKING SPRINGS FOR OUR CARS.......the guy from andysautosport told me eibach is in the research and development stage for newer "better" springs....idk...he said its a rumor going around.
I checked other sites....not in stock
i might have to go lower
09-28-2010, 09:01 AM
well if i could get bdyman's stuff i would but im really short on cash with trying to keep $$$ for the engine and all that i am gonna need to get it in and change fluids
09-30-2010, 01:54 PM
So to conclude, Do you DONT have to get a camber kit? I'm about to put gr2 struts with springtech springs. Will i need to have an alignment? and do i need a camber kit? Sounds like no kit due to slotted struts, but alignment is still a must? just want to be sure i get it right.
"How did you MELT the spark plugs!?"
09-30-2010, 03:15 PM
no camber. yes alignment
09-30-2010, 04:05 PM
Will the Grand Am springs not work? I assumed they would because that was my plan. The only thing I noticed before the aleros were discontinued was they offered less of a drop than the GA.
$239.95
http://www.summitracing.com/parts/EIB-3875-140/
Brand Eibach
Manufacturer's Part Number 3875.140
Part Type Lowering Springs
Product Line Eibach Pro-Kit Lowering Springs
Summit Racing Part Number EIB-3875-140
UPC 803050127679
Make PONTIAC
Model GRAND AM
Beginning Year 1999
Ending Year 2005
Engine Type V6
Liter 3.4
CID 207
Engine Size 3.4L/207
Engine Family GM V6
Amount of Drop Front 1.200 in.
Amount of Drop Rear 1.300 in.
Drivetrain FWD
Chassis N-body
Body Style Sedan
Doors 4-door
One Bolt at a Time.
09-30-2010, 04:11 PM
If you make any change to your suspension or steering, you always get an alignment. Period.
Should work, Grand Am and Alero are identical in everything but interior and body other than the unibody.
1987 Honda Rebel 450
09-30-2010, 06:12 PM
come spring time ( when ill be installing new struts and lowering springs ) I am putting a new camber kit on it as well since mine looks like if I needed to adjust the rear camber ( just had it aligned yesterday and rear camber is slightly off by nothing major ) so new cambers won't hurt anything I mean its only an extra $30 why not do it
09-30-2010, 06:47 PM
or you could just buy some grade five bolts for $5
