07-14-2011, 01:17 PM
Pacestter headers question!
Okay, so i ordered some pacesetter headers. Was workin on the car last nighr taking off the manifolds so i didnt have to mess with it. Headers come in later today.. But there is two things i ran into...
1. A stud broke off into the head. Gotta figure out how im gonna drill it out.
2. I asked xanderwifi about his car cause he has the same headers... He wasnt sure but does the pacesetters come with an egr port or do i need to block it off?
Thanks for the help.
07-14-2011, 01:45 PM
Have fun with that broken bolt that sucks!
07-14-2011, 02:19 PM
Thanks eric lol it will suck...
07-14-2011, 02:23 PM
I have S&S headers and they have an EGR port, but if your headers don't have one Ben at WOTTech sells a block off plate that goes on the UIM
07-14-2011, 03:16 PM
Or i could make one? Also does it throw a code if its not there?
07-14-2011, 03:59 PM
How does this connect to the cat/downpipe!
07-14-2011, 04:13 PM
You will need to take it to a exhaust shop and have the cat cut down and custom made to work.
2002 Grand Am GT Turbocharged
07-14-2011, 10:34 PM
Will the egr set off a code if its not there
07-15-2011, 12:19 AM
^Yes it will.
07-15-2011, 03:13 AM
Thanks. I put it back on. Its 3:11am here almost finished, gotta finish the custom downpipe, cut part of the radiator fans cause its sitting against the header. Hook up the o2 sensor, bolt up the exhaust and i should be set. Oh and Put the intake back on
07-15-2011, 02:02 PM
Car is done, runs fine, pics will be up soon
07-15-2011, 03:12 PM
gotta make a youtube vid man.
07-15-2011, 04:10 PM
How do you find the power? Other mods?
07-15-2011, 06:15 PM
Not coated headers in Indiana will rust and fall apart quick... I give them 2 years
07-15-2011, 06:21 PM
Maybe so. All headers rust... And ill have to figure out the youtube vid, dont use it
07-16-2011, 08:12 PM
Hey sleepy I can make a vid for you tonight
07-16-2011, 09:33 PM
Alriight sounds good
07-25-2011, 07:01 PM
getting the stud finished up today, i still have yet to take pictures.....
07-31-2011, 12:03 AM
howd you fix the stud problem? how much it cost you?
and did you use a gasket connecting the bottom of the headers to the exhaust piping? if you did, whered you get it from?
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
