04-30-2013, 07:01 AM
problems but in the right area now
Ok well this continues on from the posts that were made about my car problems in the for sale as we were trying to figure it out but nas i put some fresh gas in it about at half a tank now and tore everything apart put the tensioner on again and checked all hosses wires and everything down to the pube on a fly and everything is hooked up im thinking it is prob the camshaft sensor im not for sure but it wants to run its just when i give it gas it chugs then dies or will rev up to 5k and die and there is no codes at all or stored codes
2004 olds alero R.I.P 242,500
1995 f-150 5.0v8 5sp 143,xxx(redneck truck)
Now searching for a new Ho!
Originally Posted by Redog
He no crazy, he WIALERO!!
04-30-2013, 07:13 AM
everything down to the pubes? damn. never knew cars grew hair.
im just messin with ya.
Originally Posted by Oldsnut
Originally Posted by tipnitty
04-30-2013, 07:28 AM
Does racoon blood and hair count? Had some skin with some hair stuck in underneath by the splash guard lol
04-30-2013, 07:36 AM
ewww lol
04-30-2013, 07:40 AM
Only hit the dam thing doing 75 lol i didnt see him then when i finally did it was to late but oh well once i get he running again ima take her to a car wash that pulls. Threw and also does the underside
04-30-2013, 11:52 AM
check to make sure the plug wires are on correctly
04-30-2013, 12:02 PM
also are there any vacuum lines in that area
04-30-2013, 04:12 PM
There all on correct
04-30-2013, 04:13 PM
Yes but there connected
04-30-2013, 05:36 PM
video
04-30-2013, 07:13 PM
Yae il send it to ur phone since i cannot upload it with my phone on here
04-30-2013, 07:47 PM
Nvm broke the dam phone but I have no spark no vac pressure and air fuel is reading straight lean no movement and its getting fuel
04-30-2013, 08:14 PM
check your wires that plug into the coil pack also check your cranl position sensor that will prevent spark as well
05-01-2013, 02:06 PM
Well I'm gunna replace it today hopefully its it
05-04-2013, 11:01 PM
News update its got spark and fuel and now it's either crank position sensor or cam position sensor
05-05-2013, 02:17 AM
Found the one that's needs replaced I did some reading and found out there is 2 one by the crank shaft pulley for fine tune fuel injection 24x and the 7x one is the main one to make it run only 15$ for it not bad! Gunna try getting one today hopefully it runs!
05-06-2013, 11:10 PM
reflash???
or have you tried disconnecting the battery for at least 30 min (usually 10 min is fine but to be sure the computer resets)...or check tps because yesterday i forgot to hook mine back up and it took forever to start and when it did idle started at 2k and worked up and was a little rough
05-07-2013, 12:50 PM
any update yet
05-07-2013, 12:58 PM
I think he gives up on it because his sensors didn't work, because last night he listed it for sale on appleton's craigslist
05-07-2013, 06:09 PM
Yae I have up I need a car so I can get a job I'm broke like a bum it's on Appleton cl and Milwaukee and I had a guy call and told me to turn the key on for 10 min and the security light start flashing and never did so after I get it to the shop and see if they can fix it then il keep it I'd just have to loan more money from gf
