Old 06-21-2010, 03:51 PM   #1
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
odometer
my odometer and gear indicator light (the light that lights up next to P R N D 3 2 1) blink rapidly when i press down on the accelerator.
the more i floor it, the more rapidly they blink.
i TOUCH the brake pedal, they quit blinking until i let off, then start blinking.
how do i fix this?
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 06-21-2010, 08:29 PM   #2
Monza
Monza is on a distinguished road
Loose connection? Try wiggling wires and connectors.
Monza is offline   Reply With Quote
Old 06-21-2010, 08:39 PM   #3
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
do you have aftermarket gauges? if so, check the connection on the ground. (all those connections, for that matter.)
Old 06-22-2010, 01:08 PM   #4
white04alero
That's the thing, I have stock gauges, ive never had the gauges out of the car. Could I have put a fuse that is too large in?
Old 06-22-2010, 02:40 PM   #5
Monza
The amp rating of the fuse will not cause flickering lights.
Do they only do it in daylight (bright) mode, or also in night (dimmed) mode?
Old 06-22-2010, 08:03 PM   #6
white04alero
it does it whether or not the headlights are on.
is there a chance the plug or ground could have become loose?
how do i get to the ground for the gauges to check?
is there a write up on how to remove the gauges so that i can check the plug/ ground?
