Old 12-01-2007, 12:01 PM   #1
hvac images on dash ......
I m glass gauges in to the cubby hole my question is :
does any one sell a hvac overlay?
how do you paint the hvac area and not lose the images for the selector knobs on the dash ?
i might redo the whole peice if i can redo the images. and keep the light showing thru
Old 12-01-2007, 12:14 PM   #2
Naich
The Founder
Naich's Avatar
Most people tape off the oval with the hvac controlls. Otherwise, you'll have to tape off just the areas where the light shines through, and that would take a lot of time and skill.
Old 12-01-2007, 05:44 PM   #3
gauge pod install....
sneak peak ......
pics of my cubby hole gauge pod. going to glass this week or next weekend.
Im going to try to keep the cup holder for change and stuff. Im going to tape the two peices together and cover the botom peice of trim with foil then glass the top one. so then i can seperate them.
Old 12-01-2007, 09:51 PM   #4
Vinalero
Vinalero's Avatar
I like the idea, will make a clean install
Old 12-02-2007, 04:15 PM   #5
thanks
ready to glass!!
