Old 02-02-2005, 06:42 PM   #1
FormulaNERD
ok, car was acting funny, and since i had another alternator that i picked up from another member cheap, i decided to change mine out. i took some pictures, and made a really simple how-to... this is a very easy job, i'd say 2/5 in difficulty.
Step 1: Remove serpentine belt from ONLY the alternator pulley
: Insert 3/8" drive ratchet without a socket into belt tensioner as shown in picture
: Push toward passenger seat and slide belt off pulley (toward passenger side wheel)
Step 2: Loosen and remove bolt closest you as shown in second picture
Step 3: Using a 6" extension and a universal joint, loosen left bolt on the rear of the alternator as pictured
Step 4: Using the same method as above, remove nut on the right rear side
Step 5: Disconnect the wire harness plug on the front (shown in yellow)
: Rotate the Alternator to the left (passenger wheel) to access the output terminal and remove rubber boot by sliding it down away from the nut.
Step 6: Remove the nut mentioned in step five (you may have to hold the nut/bolt it's attached to with a wrench as it may twist when you try to loosen it
Step 7: Pull Alternator out, replace with new one, and reverse each step mentioned to reassemble
i hope this helps someone :thumbsup:
total time... 20 min while taking pictures in the dark
Old 02-02-2005, 09:49 PM   #2
-Alero-
-Alero-'s Avatar
so did the belt just come right off, with out any trouble?
AUTOBOT
Old 02-02-2005, 10:32 PM   #3
FormulaNERD
yes, if you follow step one and apply pressure forward (toward the pass. seat) all the tension on the belt is released, and you can easily remove it.
if you're weak, try using a longer ratchet handle/breaker bar or a cheater. i'm a big guy, and probably make it sound easier than it will be for the average joe.
Old 02-05-2005, 12:13 PM   #4
turtles_ride
turtles_ride is an unknown quantity at this point
Send a message via MSN to turtles_ride
I bought smokinAMDs blue powder coated higher output alternator. So after i take out the old one its just a straight swap?
turtles_ride is offline   Reply With Quote
Old 02-05-2005, 02:18 PM   #5
FormulaNERD
yes, should be the same exact procedure. inspect the alternator, there should be a plug receptacle (pic in step 5) and an output terminal (same picture, circled in red)
Old 03-06-2005, 11:14 AM   #6
bigd6983
ok but heres the question though, in an ebay auction when swapping with a higher output alternator it strong recomends upgrading to 4 gauge wire, from the alternator to the battery.......to anyone who has put in a larger amp alternator and done the wire upgrade, exactly where does that 8 or 10 gauge wire run to from the alternator cause i can only follow it for so long......ive been lookin to do this upgrade cause i think mines about to end its life anyway.....anyone whos done it please post
Old 03-06-2005, 02:51 PM   #7
jackal2000
Keepin it Real
jackal2000's Avatar
^^^good question, i am switching to a high output alt tomorrow but i wasnt planning on changing any wires :unsure:
2015 Audi SQ5
Old 03-09-2005, 11:47 AM   #8
bigd6983
alrite cmon people i know some of you have done it.......and it makes sense to upgrade the wire seeing as you will have way more amperage......it looks to me like it runs to the distribution block under the hood and then from there to the battery but im not too sure.....
Old 03-09-2005, 01:05 PM   #9
FormulaNERD
even the "high output" alternators for the alero arent really that high output, wiring probably isnt an issue.
Old 03-09-2005, 01:17 PM   #10
bigd6983
a jump from 105 to 160 amps is a decent size jump......i know id feel more comfortable with a thicker wire.....another 55 amps is enough for me to wanna upgrade that weenie size wire thats on there right now....
Old 03-09-2005, 01:38 PM   #11
FormulaNERD
well how much current can 8 gauge carry? that's the question.
Old 03-09-2005, 01:59 PM   #12
jamcllw
Doesn't exactly answer Formulas question but it does have a nice chart for automotive wire sizes.
http://www.kayjayco.com/techPractical.htm
Old 03-09-2005, 08:21 PM   #13
FormulaNERD
good find
Old 03-09-2005, 08:22 PM   #14
jackal2000
Keepin it Real
jackal2000's Avatar
so that site is basically saying that the factory installed the wrong wire to begin with :o
or am i not reading it right?
2015 Audi SQ5
Old 03-09-2005, 08:24 PM   #15
bigd6983
yea so 4 gauge would be better to use.......i dont know about you guys if something is 105 amps and maybe the wire can handle up to 110.......id rather spring for an upgrade the test those extra 5 amps.......just makes me feel a little safer.....
Old 03-11-2005, 01:53 PM   #16
jackal2000
Keepin it Real
jackal2000's Avatar
just got the alt installed, i'll let you guys know if i have any issues.
2015 Audi SQ5
Old 03-11-2005, 08:47 PM   #17
bigd6983
well i hope you dont, maybe you can run it for a while and then do the 4 gauge swap and let us know if you notice a difference.......
Old 03-12-2005, 11:36 AM   #18
jackal2000
Keepin it Real
jackal2000's Avatar
after driving the car around town for a bit last night i stopped to check the wire and it was hot as f***. 4 gauge wire is definitely in order.
2015 Audi SQ5
Old 03-12-2005, 11:56 AM   #19
FormulaNERD
any wire sitting right on top the engine is gonna be hot as f***, lol.
but let us know how the wire swap goes.
Old 09-25-2005, 03:55 AM   #20
kampfer422
well, upgrading is definitely needed. 8 gauge wire over a 3ft span is only good for like 600watts of power or less. Take a look at this chart and it will help you 12V Wiring Sheet ,so i would expect you need atleat 4 gauge, 0 gauge would be better. But you will be doing the big 3 upgrade which is alty to battert postive, negative to ground and alty to ground. I think also it is suggested you up the fuses also but thats just what one guy who was going to rebuild my alty said to take full advantage of the upgraded alty. Right now i bet you aren't even getting half the power that alty can give. My friend had a rebuilt 120amp alt for his camaro and that was such a good alt, when he turned on his headlights and gave it some gas, the interior lights actually got brighter.
