09-29-2008, 12:54 PM
CAI 2 in line filiters?
hey guys. im not sure if anyone else had posted about this but would there be any benefit in having 2 cone filter inline on my CAI? i bought a CAI from ebay which works great but if read my other threads i always have a problem when it rains because the filter gets wet and my car cuts off.
so i was wondering if i put a filter right after the MAF and then connect the rest of the CAI after the filter, would that provide any additional benefit? and would it also prevent my car from shutting off during a torrential downpour.
below is an old and bad picture but that black rubber piece over on the right is where the filer would go. and then the rest of the CAI.
09-29-2008, 01:02 PM
wtf are you talking about just set up a CAI in the wheelwell and keep the rain from getting into the filter with the plastic wheelwell cover that comes with the car.
09-29-2008, 01:05 PM
everything that came with the car is there. the wheel well, the plastic cover around the fog light, etc. all that is there. it still gets wet. dont ask me how or why
09-29-2008, 01:10 PM
you should fab up the pipe so that the filter sits higher and doesnt get wet, it shouldnt and mine didnt get wet for the year and a half i had it
09-29-2008, 02:17 PM
New and Improved
bypass valve anyone?
09-29-2008, 02:46 PM
bypass? isint that dangerous for a "no filter period?"
09-29-2008, 03:17 PM
i saw someone that had 2 filters once ... i dunno how good it worked tho. he had one of those plastick flexible tubes autozone sells connected to the end of his first filter then that went down into the fender and had another filter on it. looked kinda dumb actually.
09-29-2008, 03:23 PM
You noob. The AEM bypass valve is a filtered device that closes off the intake piping that leads to the water and air is sucked in through that bypass valve until the water is gone.
If you're sucking up that much water, you need to pull your car out of the lake. The only way you can suck up water, or enough to hydrolock an engine is by having the end of the intake pipe completely submerged.
09-29-2008, 07:28 PM
i know im not hydrolocking. im just tired of the filter getting so wet that it cant suck air properly, so i thought why not have 2 filter in-line? bad idea?
09-29-2008, 07:35 PM
It will make your "CAI" useless. Air will be sucked in through the closest filter.
Get a better filter. Even when I drove through torrential rainfall for 4 HOURS and through massive puddles and such with my CAI it was slightly wet.
09-29-2008, 08:23 PM
Boost Guru
Says who?
I think being the big, reputable company that they are, AEM made the bypass valve to work properly and not make their own CAI's useless.
This is what it looks like underneath the foam filter:
There's little urethane flappers that are normally closed, allowing the CAI to work just like a CAI should. When the filter gets submerged or soaked in water, the increased vacuum created by that restriction on the filter pulls open the flappers and air gets sucked in through the bypass valve instead of pulling water up through the intake tube.
It's a great idea to add a bypass valve if your engine's sucking up a lot of water...should fix your problem.
09-29-2008, 08:25 PM
New and Improved
um i think c2 was arguing FOR the bypass?
09-29-2008, 08:29 PM
Boost Guru
09-29-2008, 08:30 PM
New and Improved
he was referring to the 2 filters on the cai, not the bypass valve, i beleive
09-29-2008, 08:32 PM
haha bad99olds got it on, lol @ spilner. the bypass valve opens only when the normal filter is clogged with water.
09-29-2008, 08:41 PM
i saw go for the 2 filters. show ion what for!
09-29-2008, 08:43 PM
New and Improved
i really think the 2 cai thing is mildly useless. its going to suck the air from the closest filter first, which would be the warmest. go with a straight up cai and get the bypass valve, and call it a day.
09-29-2008, 08:55 PM
There's no way the bypass valve would open and prevent water from coming up from a few splashes getting through your filter like you seem to be getting somehow. That won't cause enough vacuum for it to open; only when the end of the pipe is completely submerged, which won't happen unless you drive through 2 feet of water. I have a CAI and am sucking with much more force and have been through some of the nastiest wet weather possible.
