04-19-2009, 12:27 AM
AutoCross Alero
Up on jack stands for a new project.
The time has come to replace a few parts. new front lower control arms with ploy bushings, new drivers side axle, new tie rod ends, new braided stainless brake lines and super blue 538 degree brake fluid, new poly swaybar bushings, and front poly motor mount, and those are my new back tires 255/40/17 falken azenis, i'll be putting my 245/40/17s on the front. also doing a new thermostat, waterpump and belt.
04-19-2009, 12:32 AM
nice. I could use most of those parts. I need to replace my control arm bushings and passenger side half-shaft. I have also been considering the idea of SS brake lines.
good luck with the install! I am curious for feedback on the poly bushings and brake lines.
04-19-2009, 12:35 AM
nice tires!!
04-19-2009, 12:36 AM
Why so big on the rubber?
You got some hidden horsepower that you're keeping secret?
04-19-2009, 12:37 AM
AutoCross Alero
sticky rubber and fast corners.
and yes, new engine plans i'm not discussing yet.
04-19-2009, 05:48 AM
Boost Guru
You got it the wrong way. You want the wider tires on the front. Unless a RWD conversion is in your plans.
04-19-2009, 10:14 AM
x2, fatties in the front, skinnies in the rear!!!
AutoCross Alero
true for a straight line, but not essentially for cornering. and it would just look stupid.
04-19-2009, 11:18 AM
i'm gonna have to disagree, you can hardly tell that i have smaller tires in the back on my car
04-19-2009, 06:17 PM
Boost Guru
Sorry, wider tires up front for cornering also on a FWD car. As far as how it looks, you'll barely even be able to tell.
The newer Grand Prix GXP's come with a FWD staggered setup from the factory, something like 255's up front with 225's in the rear.
04-19-2009, 06:29 PM
AutoCross Alero
ive had my rear end swing out on me, never had problems with the front.
04-19-2009, 06:56 PM
oooooooo, nice shiny new parts for the car I like...... i wanna do braided stainless lines too.... i heard they improve braking A LOT.....make the pedal a lot stiffer
04-19-2009, 11:00 PM
Boost Guru
That's nice. The wider tires should still go on the front if you're going to track or autocross the car.
04-21-2009, 10:55 AM
all that looks nice damm*drool*
04-22-2009, 03:05 AM
Not bad, I have new alloy control arms to go on mine someday.
04-25-2009, 06:55 PM
AutoCross Alero
changed my motor mount today, and after 115000 miles it is completely wornout. put a poly mount in its place.
