01-21-2010, 12:41 AM
wheel bearings
ok. wheel bearings is my assumption, but i want to make sure it isnt something else before i spend money on bearings and dont need them
when i drive my alero, i feel, not so much hear, but feel a humming vibration coming from the floor boards. its not worse when i turn the wheel either way, and i dont know if its on the passenger side or not, but it is for sure on the driver's side. is it wheel bearings?
oh and on struts - my front struts have always kind of creaked a little bit, but the creaking has gotten much louder, and the rear has started to creak, but only sometimes. do they need replaced?
ive got the 3400, and about 82,xxx miles on the car right now.
TIA
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
01-21-2010, 01:48 AM
The Aleromod PITA
creaking can be bad strut plates, the bearings in those go, atleast thats the issue with mine, ive done a couple bearings
01-21-2010, 10:57 AM
Well at 82k miles on a 6 year old car you're already due for strut replacement, do all 4 at once so you only have to do one alignment afterwards and it will cost you 500 or less total.
That humming sensation isn't always wheel bearings, it can be a hub or even the tire itself. Inspect and rotate the tires when you do your struts, see if it makes any difference and see what happens, you'll figure it out sooner or later.
01-21-2010, 11:00 AM
btw, hub = bearing...
well, if you have no lights, and it's not a hearable humming, don't worry, what kind of tires do you have?
and do ALL struts/mounts... so easy to do yourself also.. and lower it while you're in there
01-21-2010, 11:48 AM
i thought about lowering while i was doing the struts, figured i would.
and the tires i have are goodyear viva 2
could it just be road noise??
01-21-2010, 03:44 PM
No those tires shouldn't make much noise unless there is some unusual wear or damage to them.
01-21-2010, 04:04 PM
I have those tires too, not too shabby. Pretty good traction and are really quiet.
01-21-2010, 07:21 PM
TIA
Well you need to repalce the hub(s) that are making the noise...
struts replace all and spings that you want ....
eibach are good for 1.5 front and 1.2 rear...(you can cut the rears if you like.)
cost for someone to do it fron 450 to 650 with aligment.
I would get quotes before...and you might find the struts cheap online..
good luck.
BUILDING A V8 ALERO 2DR
01-22-2010, 06:48 AM
For the wheel bearings, jack the car up. Grab a wheel and see if its loose.
My bearings started out as an annoying hum, then vibrations, then death.
01-22-2010, 06:52 AM
mine is at vibrations.... did the noise stage for 34K miles... braking.....vibration
accel...MAJOR vibration, and my daily commute is all highway.... tree here i come!
01-22-2010, 08:51 AM
ok i seen somethin about lowering the car while he was changing the struts i
want to lower mine but i dont know where to get the spring so can somebody
point me in the right direction to some good springs
