07-07-2008, 10:40 PM
Rear brake disc conversion questions
well i did some searching and found that it could be done......
what would i need to do to the car to get it ready for the conversion and what parts do i need to do the conversion....
help is appreciated(please dont bash if i overlooked something i could have found on the forum)
07-07-2008, 10:53 PM
interested to
iv been thinking bout doint it on my car also im assuming basically the whole rear assembaly like hub backing blate caliper, and different lines. i guess idk really
07-08-2008, 02:11 AM
all the parts from the spindle out, the brake lines as well as the parking brake cables.
07-08-2008, 04:58 PM
brake lines? arent they already there?
07-08-2008, 09:28 PM
Let's Play Army!
need different ones for disc...routed slightly differently based on position, and it affects the length of the lines.
basically, if you know your way around a car, it's an easy task...although...all day. but if it's your first brake job....eep!
Originally Posted by black
07-08-2008, 09:30 PM
i think the best/cheapest place to get the parts is a local junker. find an alero that has a destroyed front end and steal the back brakes/assembly...
but yes, it is quite an overhaul if your still a little green at car work. (i certainly wouldn't attempt it) and besides, all your really changing is appearance. drums work just as well.
07-08-2008, 09:46 PM
Let's Play Army!
discs in the rear do help take some of the brunt off the front.....and I did NOT intend for that to rhyme.
07-09-2008, 02:16 AM
I guess more properly I should say brake hoses.
07-10-2008, 03:55 AM
Would you not also need the master cylinder fom a 4 wheel disc brake car? Would the proportion of brake pressure going to the rear wheels be different on a rear disc, than on a read drum setup??
07-10-2008, 12:27 PM
Nah, there's no different part number for it. There may be something different with the programming in the EBCM (if you have ABS) but I haven't checked that.
07-10-2008, 02:46 PM
Some of these came with drum brakes in the back?
07-10-2008, 03:02 PM
Let's Play Army!
yeah, GX and minimal option GL's.
07-11-2008, 01:45 AM
More accurately all 03-04 GXs and 4-cylinder GLs that are not fleet orders, as well as V6 GL models without ABS.
99-02 were all standard with 4 wheel disc/abs
07-11-2008, 08:30 AM
Let's Play Army!
thanks for clearing that up...I knew there was a more specific answer to that
08-15-2010, 03:14 AM
The Aleromod PITA
i know im pulling this up from the graveyard but i been looking into this, i have the junk yard to get the parts i think the man said 80 bucks for anything id need for the job (he's really leanient on pricing stuff) and i want to know if the computer code is different
