05-25-2010, 03:48 PM
3400 Sputtering on Startup
Well lately ive been driving my chickies Alero and everytime i start the engine, its sputters for about 10-15 seconds, and wont stay on without pressing the peddle a slight amount. When I have the car warmed up turn it off, then back on and dump it in drive it wont turn off.
Heres what ive done so far.
Reman Mass Air Sensor
New TPS
New IAC
New Vapor Purge Valve
New Coolant Temp Sensor
Replaced PCV valve and hose assembly
New Plenum Gasket and TB gasket.
This is pretty annoying this is my second engine the first one had a few lifters take a dump, but still had the same problems with the old parts.
What should i do next?
05-25-2010, 05:35 PM
Any SES lights?
To me, sounds like injectors or fuel pump. Something fuel related.
When Nate chimes in and says "Head Gasket" just ingorne it
05-25-2010, 05:50 PM
Originally Posted by Redog
Any SES lights?
The SES light is on i forgot the code number but I remember it being related to the charcoal canister. But thats it.
Also about 4 years ago I replaced the Fuel Pump and I forgot to list I replaced the Fuel Pressure Regulator last month.
1999 Alero 3400
Just hit 210,000 miles bisches
05-26-2010, 11:22 PM
I scanned the car today and got three codes.
P0172 System too rich (bank 1)
P0452 Evap. Pressure sensor low
P0453 Evap. Pressure sensor high
1999 Alero 3400
05-26-2010, 11:38 PM
This sounds similar to a problem that I'm having with mine, including the 172 code and small evap leak code. I was told to calibrate the tps sensor that I just replaced but I dont have the time to do that now. Maybe that could be something you could try? I dont know if our cars have adjustable tps's.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
05-26-2010, 11:48 PM
Redog, you need to change your brain fluid and check your intelligence filter,
Sir, methinks you have a Vacuum leak.
05-27-2010, 12:09 AM
Im not sure if the TPS is adjustable. Any chance the that charcoal canister is bad causing a rich condition? The engine I have has about 124,000 so Im thinking the Front O2 sensor is good.
1999 Alero 3400
05-29-2010, 11:03 PM
I replaced the MAP sensor yesterday, got a new fuel cap and erased the SES light. Now the only trouble code I have remaining is P0453. So far the car doesnt sputter,surge or die on startup.
1999 Alero 3400
06-26-2013, 10:28 PM
evap purge valve
Im having a similar issue with my 02 Alero v6 and it started when ya first start it it runs funny for about 6-8 seconds then it smooths out about 3 days ago. I went to oreillys and a friend of mine scanned the ses light for me and it pulled up evap system purge valve malfunction. I have a new fuel pump(DELPHI), new MAF,new ignition coils,Tuned pcm from mp racing, deleted Catalytic Converter,deleted 2nd O2 sensor. Now i did install OBX headers with FelPro factory style gaskets and it threw a code for running too lean but it was an exhaust leak and i fixed that. Im at a loss on how to get the ses light to go away!!
06-27-2013, 07:30 AM
way to revive an old thread haha.
what code was set? "flow during non purge event"?, circuit codes? the number would help a lot.
06-27-2013, 02:57 PM
evap purge valve
I know right lol!! I searched forever and finally got tired of lookin lol i didnt catch the exact code but im gonna go back up there today and write it down and ill post back and let ya know.thanks
