08-13-2009, 12:59 AM
dash board gauges
ok i put the leds in my gauge cluster and they worked perfectly fine i have had thenm in well over a month and have never had a problem so i installed a new tv radio head unit and i installed some fog lights by the time i installed the fog lights it got dark enough for my headlights to cut on automatically and the dash and prnd321 worked fine so i finish the foglights and leave the car alone come back out the house about an hour later and move the car up in the drive way dash light and everything still work so about 2 hours after that i leave my friends house and i notice my dash light dont work anymore now i did remove the two relays that control the auto lamps but the dash and everything still worked with out them when i had moved the car up but they didnt work when i got ready to leave so i put the relays back in i got nothing just all my headlamps and everything else that was suppose to light up did except for my dash and shift area not the gauges work the lights wont come on the idiot light and the turn signals work fine also so can somebody please help me this is really p!$$!ng me off
08-13-2009, 01:02 AM
New and Improved
I know exactly what you problem is.
You dont know how to use punctuation.
08-13-2009, 01:07 AM
i really didnt ask for a grammer lesson i just want help with my car and if your not goin to help dont reply
08-13-2009, 01:14 AM
Check your fuses. If you used the ilumination wire in your harness when you installed your headunit it may be incorectly hoked up.
08-13-2009, 02:16 AM
The Aleromod PITA
Originally Posted by broken__one
Check your fuses.
second
08-13-2009, 08:08 AM
if you make it unbelievably difficult to read, i guarantee, the majority of people who know what they are talking about, will just close the window before they make it half way through. Punctuation exists to make life easier. This isn't ancient Rome... use it!
now on to the problem. Most likely.. its a fuse. passanger side panel, top right. If not, there is also one under the hood. #45? can't quite remember, but it sounds familiar.
Also, your PRND321 and gauges are out? (all interior lights?)
08-13-2009, 08:13 AM
QFT i just did this
08-13-2009, 08:58 AM
New and Improved
m-hm-m-m-mmmmm. Now onto your actual problem, aside from your pisspoor grammar, it deffinitly sounds like a fuse.
08-14-2009, 12:00 AM
sorry about the grammer it was late i was pissed and been up for the past 36 hours running off of nothing but mountain dew i know not good
i checked my fuses and nothing was blown but i didnt hook the illumination wire up on the radio at all i have never used it on any intstall i have ever done before but maybe that could be it ill check the fuses again just to be sure and ill let yall know if i still have the same problem
sorry for the short temper and thanks for the help
08-14-2009, 12:09 AM
listen PLEASE use comma's!!!!!
i get this out of your sentence
huhowareoyuimalrightwtfdidyoudotodayyoustupideffi hateyouasswiperoostersuckingpieceofshitcheatingloser!
hmm, take the cluster out and check for blown bulbs? may be there was a surge (sounds like you have an audio system, so im wondering if a surge happened and blew the bulbs)
08-14-2009, 01:25 AM
huhowareoyuimalrightwtfdidyoudotodayyoustupideffih ateyouasswipechickensuckingpieceofshitcheatinglose r!
your impression of me typing is funny because i actually understood
what you typed and i have leds in the cluster so i cant just take them out and look a them to see if they are blown
and if there was a surge how come everything else on my gauges work
wouldnt it have blown the entire thing or better yet why wasnt the fuse blown
im just askin not tryin to sound like a smart @$$
i have some electrical back knowledge i really didnt pay attention in class
but i thought thats what the fuses was for so you dont damage anything in your car
08-14-2009, 02:42 AM
Punctuation dose make reading a little easier. my eyes were crossing trying to read your post >_< It may not seem like a big deal compared to your car, but if people cannot read your post well, then they cant give an answer.
O and its good to see another Michigan Alero guy, you should caravan with us to the summer meet/cook out thing. lol
1999, RED Alero GX
08-14-2009, 03:20 AM
I'm having the same issue with mine, and all i can think of is the wiring at the radio. I have changed bulbs, fuses, and some wiring. The guy that fooked up my radio install may have put wires in the wrong places, so make sure your stuff is connected correctly, and that its all plugged in.
DEATH BEFORE DISMOUNT!!!!
MPs lead the way!!
08-14-2009, 08:28 AM
your dimmer switch might be shot.
did you PULL the fuses out and TEST them? (continuity meter)
you might have shorted something. (connected a power to a ground somewhere)
work backwards. Disconnect the last thing you connected, and see if anything comes on. If not, then move to the next one back from that.
08-14-2009, 09:49 AM
ok ill try both of those but i dont have that meter any more it was stolen
is there a way to check them with out the meter
and ill go back and check the radio connections i do have one question would the illumination wire need to be hooked up in order for the dash to work right
08-14-2009, 09:53 AM
New and Improved
still no punctuation? lol
08-14-2009, 09:30 PM
No you don't need your ilumination wire hooked up, but if it is just cut and not caped it could have shorted out.
The other thing is if you crossed the wires during instalation if you used a harness kit.
08-14-2009, 11:15 PM
ok i kinda figured that and i did leave it uncapped. but the leds work and no fuses are blown could i have fried the gauge cluster all together.
08-14-2009, 11:46 PM
now, someone wants to tell me this.......but you weren't talking to me I know. Anyways, which wire is the illumination wire? If i can check that myself it will save me the money I was gonna spent re-wiring the whole car :P
MPs lead the way!!
08-15-2009, 01:02 AM
^^The gray wire is the ilumination wire.
