02-17-2008, 01:35 AM
#21
i thought that all 3.1s and 3.4s where vacume operated.
02-17-2008, 01:45 AM
#22
Originally Posted by Spilner521
I've had my Shiftplus on my car for over 3 years, 2 of them turbo'd, and I've left it on setting 2 the entire 3+ years without any problems. Still shifts very fast and there's been zero transmission problems.
Is it turned on all the time?
02-17-2008, 01:51 AM
#23
You know, I had my trans rebuilt at an Olds dealer at 60k miles because of the sloppy 1-2 shift (it gradually got sloppy over a long period of time). After the rebuild, it repeated the same thing, getting worse with time and now, at 108k, the 1-2 shift feels sloppy again. I think it's just normal wear in the trans and the PCM programming doesn't adjust for it with higher pressure.
02-17-2008, 02:37 AM
#24
Boost Guru
Yep. The day I installed it I tried it out on both settings. I liked setting 2 so I switched it to 2 and haven't touched it since.
02-17-2008, 09:45 PM
#25
Any warning lights or SES lights?
02-17-2008, 10:03 PM
#26
nope...they're a 4T45E
the "E" is for electronically controled
2000 Chevrolet Malibu LS
02-17-2008, 11:50 PM
#27
Only the old GAs and Achievas with the 4T60-E were vacuum.
02-18-2008, 12:20 PM
#28
Do you have the B&M Shiftplus on yours?
02-18-2008, 12:50 PM
#29
nope because i'm afraid that it'll eff up my trans worse than it already is.
here's a gm goodwrench webpage explaining transmission identification:
http://www.goodwrench.com/_res/pdf/T...tification.pdf
02-18-2008, 08:13 PM
#30
Does anyone know if I can put a newer trans in my 2000 Alero 3.4L? How new can I go? I heard some of the newer ones have some mods to make them last longer.
02-18-2008, 08:38 PM
#31
installed this 2 wks ago and it is a great mod, but does anyone get a big clunk when putting it into gear once the car is warmed up??? in setting 1 and 2
02-19-2008, 01:16 AM
#32
Owner
this is normal with the higher pressure from the pump.
you should hear and feel it with the poly mount and coilovers............SLAM
Beware of the BackStabber
