if it is just your light that is turning on and you have no leaks replace the coolant bottle, but if you do have a leak it is most likely the internal seal on the waterpump. if your mechanic said it was leaking did he show you or did you ask to see the leak he might be saying that to get some work. if it is the waterpump its not any easy job i did mine two months ago myself. you have to make sure timing doesnt jump that you seat the gaskets properly espiacally the timing chain cover gasket if you dont you wont have a coolant but an oil leak i ran into that problem also i would replace the tensioner, chain, and guides. i paid about $300 for everything waterpump, gasket kit from gm dealer, and new chain, tensioner, and guides
