Old 07-20-2013, 09:24 PM   #1
ndkpyro
ndkpyro is on a distinguished road
thump on hard acceleration, Rear transmission mount?
My 03 v6 has had an issue when accelerating hard locked in 1st or 2nd it will thump if you let off and then give it more gas. Motor mount is new (2 months old). Today I replaced the front transmission mount that was starting to tear. Got it all bback together and it still does it . I started to take the rear mount off to replace the insert on that one too but I can’t figure out how to get the bottom bolt out. There is not even enough room to get a short socket on there. Has anyone else replaced the insert on their rear transmission mount?
ndkpyro is offline   Reply With Quote
Old 07-21-2013, 12:09 AM   #2
It looks like the service manual directs you to do this through the left front wheel well.
I remember removing the bracket that attaches to the subframe on mine.. A manual trans, but still the same style mounting.
Old 07-21-2013, 09:53 AM   #3
ndkpyro
I did see that it says that you should take the wheel off then the mount comes out the wheel well. i looked at taking the bottom bracket off as well but my problem is there is not enough room between the sub frame and bolt to get a socket and when there torqued to 89 FT-Lbs :/. Hmm maybe I should try unbolting the through pin and loosening up the motor mount so i can tilt the whole engine forward? I will put her back up and post a pic latter of what I am talking about.
Old 07-21-2013, 11:33 PM   #4
You can lower the subframe down a bit too if that helps...
Old 07-21-2013, 11:59 PM   #5
02AleroGLS
02AleroGLS's Avatar
02AleroGLS is on a distinguished road
Wow all this is scaring the hell out of me cause my front transmission mount and back transmission mount are both bad and im fixing to have to change them soon.
02AleroGLS is offline   Reply With Quote
Old 07-24-2013, 08:48 PM   #6
ndkpyro
The front is not that bad just have to do some maneuvering around the wires. If I can ever find my camera charger I will take pics when I do it this weekend.
Old 07-25-2013, 12:05 AM   #7
Mine has done this for a long time.
Old 08-09-2013, 07:33 PM   #8
02AleroGLS
02AleroGLS's Avatar
Ok im.just curious cause im tired of blowing transmission mounts out. Does it do any good to fill the mounts with polyurethane to strengthen them up or is it just a waste of money?? I can get the urethane pretty cheap at home depot, (like $4.75 a tube). The mounts are a headache to change repeatedly as they are press in style. The closest shop that has a press is like 15 miles away and getting a ride is a real pain..
