Originally Posted by Greencoupe2.2
are they just as good or better than the delphis
These newer Delphi, Airtex, and Carter replacement modules are not exactly the same and not as good as the original Delphi that came with the vehicle. That's my opinion based on just comparing the build quality and construction. But I believe any of them will do OK for your application. If I had to choose, I would try a Carter, but I have not used one as a replacement.
Be sure to keep the original canister, possibly at a later time get a Carter pump (if available) and new filter screens to rebuild it.
According to someone here at NAPA, you can also order a Bosch replacement module, which I would do if it were not so expensive, I think it was twice as much as the Delphi.
